Hi,
I'm having trouble with the Hector_slam tutorials, i'm running ROS Kinetic on Ubuntu 16.04.
When i try and run the launch file i get the following:
[rviz-1] process has died [pid 2487, exit code -11, cmd /opt/ros/kinetic/lib/rviz/rviz -d /opt/ros/kinetic/share/hector_slam_launch/rviz_cfg/mapping_demo.rviz __name:=rviz __log:=/home/ben/.ros/log/a7183d30-e320-11e6-a7a4-0800279fda91/rviz-1.log].
log file: /home/ben/.ros/log/a7183d30-e320-11e6-a7a4-0800279fda91/rviz-1*.log
I have no idea why it failed, and even though it generated a log file, it didn't actually write anything to it, as when i open the associated file with a text editor, it's blank.
Any help would be appreciated. Thanks, Ben
Originally posted by Ben12345 on ROS Answers with karma: 98 on 2017-01-25
Comment by gvdhoorn on 2017-01-25:
Please tell us what platform this is, and how you installed ROS. From your other questions I gather this could be a raspberry pi, which could be important.
Comment by Ben12345 on 2017-01-25:
Hi, Ubuntu 16.04 running in Virtual box 5.0.30 on a mac. No raspberry pi. Ros was installed via the installation guidelines presented on the website - i.e sudo apt-get install etc etc. It was desktop full.
I'm not saying it's definitely the problem, but running RViz in vbox has been problematic before. Have you installed the relevant video drivers / extensions?
Also: are there more lines to the error you posted above?
And: can you rosrun rviz rviz by itself?
Hmm that's interesting, i had a few issues with the serial from a VM Ros node about a year ago so that would make sense. I'll give it a try on my dual boot tomorrow. No i cannot run Rviz by itself, i get a segmentation fault and core dump. No additional text from the original question. Thanks
Oh and 3D acceleration is enabled, and i'm running OpenGL 2.1 within the VM
Comment by gvdhoorn on 2017-01-26:
Ok. May I suggest you update the title of your question then? The current title seems to suggest this is a problem with hector_slam, but it looks more like an RViz<->VBox problem.
Ok so it seems the problem is with RVIZ and a virtual machine, as this works under a real machine.
A solution for anyone wanting to run Rviz in a virtual box VM is to disable 3D acceleration, i.e switch the VM off, go into settings and uncheck the box for 3D acceleration, i disabled 2D acceleration too.
I imagine there will be a performance hit with any graphics, but something is better than nothing.
Originally posted by Ben12345 with karma: 98 on 2017-02-03
Comment by William on 2017-02-03:
I can reproduce, but the segfault is somewhere in Ogre3D and unfortunately I don't really have time to dig into the root cause. I also noticed that glxgears caused weird behavior in the same situation. Maybe it's a bug in the VB video driver for 16.04. Not free, but Parallels works great for me.
