Hello,
I'm trying to make 3D map of my office with XtionPRO Live, the biggest problem i met so far is dealing with transparent/aborbing objects etc. I tried to avoid them but they still reflects (windows, glass doors) and i got random erros on my map (like inclined in the middle of room). Other things like glasses or bottles are hard to avoid. I couldn't find any solution and it's seems to be impossible to solve problem due to Xtion sensor is using IR.
The only thing i found is publication about combining two Xtions (http://www.cs.cornell.edu/~hema/rgbd-workshop-2014/papers/Alhwarin.pdf). I'm new to RoS/mapping and publication I found is too complex for me to implementation. I understand main assumption but I'm not sure how to prepare it and use with RTAB-map.
I am able to get second Xtion/Kinect but how should i calibrate them? Earlier i used (http://wiki.ros.org/action/show/openni_launch/Tutorials/IntrinsicCalibration) but in that way i can pass mono calibration for sensors separately, how can i combine them? Is there any way to achieve goal with available packages? Is there any other solutions to deal with objects like that in RTAB-map?
Thanks for answers.
Originally posted by necro on ROS Answers with karma: 38 on 2016-07-25
Comment by Mehdi. on 2016-07-25:
I don't to which extent you can integrate it in RTAB map but sonars are the solution to transparent objects.
