That processor is not likely to run any existing 3D or 2D SLAM implementation at any reasonable sort of framerate. In fact, I'm guessing it would likely struggle with just running the openni driver and pulling in pointcloud data from the Xtion, but that would be up to you to verify.
If this is running on a robot, you may have some luck grabbing the pointcloud, or even just the depth and rgb image streams on this processor, and doing the SLAM processing remotely on a beefier PC.
Originally posted by paulbovbel with karma: 4518 on 2014-09-12
Comment by Shubham Garg on 2014-09-13:
Thanks a lot for your quick response.
I have one more option. Can I can use Intel atom N2800 processor for performing SLAM ?? I am thinking to use this board http://click.intel.com/edc/development-kit-norco-bis-6630-intelr-atomtm-processor-n2800-rev-2.html
Comment by paulbovbel on 2014-09-13:
It all depends - 2D, 3D, realtime or offline, I gave you a basic overview but beyond that you'd have to experiment.
Comment by Shubham Garg on 2014-09-15:
Can you please tell me best possible intel atom processor for running SLAM ??
