When I roslaunch my node, the error I receive is
ImportError: No module named rospy
But when I open up the python environment and run import rospy, it imports successfully and I can access rospy.__file__, which returns
/opt/ros/indigo/lib/python2.7/dist-packages/rospy/__init__.pyc
which is on my PYTHONPATH:
declare -x PYTHONPATH="/usr/lib/python2.7/dist-packages:/home/<user>/indigo_ws/devel/lib/python2.7/dist-packages:/opt/ros/indigo/lib/python2.7/dist-packages"
I do have a custom installation of Python that seems to have messed up some catkin_pkg installation, which is why it's had to be appended to the path. When I remove it to run roslaunch as a debug, I just get the same error.
Running Ubuntu 14.04 on a Raspberry Pi, if that helps.
Originally posted by djsw on ROS Answers with karma: 153 on 2016-01-06
Comment by Humpelstilzchen on 2016-01-08:
Did you check PYTHONPATH in os.environ? What version of the python interpreter is started by roslaunch?
I worked out what the problem was.
I wanted access to the Raspberry Pi GPIO ports, so I had used launch-prefix="sudo" in my launch file. What this meant was that the file was launched in the root workspace which wasn't set up to use ROS. There is apparently a workaround that I wasn't able to get to work.
So my problem was solved by removing that from the launch file.
In case anybody finds this on google, I can use the GPIO ports in a ROS node by running pigpio. Some googling will produce an example script but this is either out-of-date or wrong - use the examples on the site.
Originally posted by djsw with karma: 153 on 2016-01-08
Comment by Falko on 2016-03-16:
The pigpio library really made my day! It's working beautifully and I can even control the raspberry gpio pins from a remote machine. (Ubuntu on both machines, ROS running either on both of them or the remote machine only, no "sudo node" involved.)
For those who still want to run a node as root despite the GPiO workaround hereabove, you must preserve the right environment variable: launch-prefix="sudo -E PYTHONPATH=$(env PYTHONPATH)"
Originally posted by Yoan with karma: 31 on 2017-03-01
Comment by bjajo on 2020-11-25:
I love you, thank you sooooo much!! :)
