Pycharm IDE doesn't seem to recognize ROS modules (It underlines them and doesn't autocomplete), even though when I run the script, the interpreter does recognize them. I should add that I am opening pycharm from a linux terminal, after I have sourced the ROS environment (/opt/ros/noetic/setup.bash) and the local catkin worksapce. How can I solve the problem?
Originally posted by amit_z on ROS Answers with karma: 51 on 2022-09-18
Comment by ravijoshi on 2022-09-18:
this may help: https://youtu.be/lTew9mbXrAs
Comment by amit_z on 2022-09-20:
Thanks! it was helpful indeed
Comment by ravijoshi on 2022-09-20:
glad you made it work.
Comment by ljaniec on 2022-09-20:
Please add a text solution as an answer, videos and websites may be taken down later, future readers then will not benefit from your help now
