I want to use fovis_ros with my xtion to build lately a 3d map using octomap , but when i start the launch file of openni2 and mono_deth_odometer of fovis package i have the following errors:
1)The camera say me that the image taken is uncalibrated. 2)Fovis_ros receive image and info from the respective topic , but the "synchronized tuples" are 0. 3)I cannot visualize in anyway the result from fovis_ros topic (features,pose,odoemtry).
Originally posted by Saracerno on ROS Answers with karma: 1 on 2015-07-16
Comment by Saracerno on 2015-07-16:
This is the code of launch files link text
Comment by Miquel Massot on 2015-10-27:
If the answer pleases you, would you please mark the question as answered?
Hi Saracemo,
fovis needs grayscale rectified images. If color images are provided, they are converted to grayscale. Please use the launchfile provided in fovis_ros github source page and your openni launchfile.
Originally posted by Miquel Massot with karma: 1471 on 2015-07-16
Comment by Saracerno on 2015-07-17:
I will try !
I had a question : Does fovis requires RGB image?? Because the xtion i had is unable. In this case , what kind of ros package i have to use to make visual odometry ?? THANKS
Comment by wsAndy on 2015-08-10:
Hi Saracemo, I'm trying to use fovis_ros with xtion this days. I use to use xtion with kinect and it could run. I use openni2_launch and my system is ubuntu 64bit indigo. Have you solve it?
