Hi all,
I'm trying to install ROS-indigo on Mac OS X Yosemite but i will be damned soon :) . I created a workspace and following code worked properly.
$ rosinstall_generator desktop_full --rosdistro indigo --deps --wet-only --tar > indigo-desktop-full-wet.rosinstall
$ wstool init -j8 src indigo-desktop-full-wet.rosinstall
but;
$ rosdep install --from-paths src --ignore-src --rosdistro indigo -y
this code produces an error:
executing command [brew install opencv]
Warning: opencv-2.4.10.1 already installed, it's just not linked
ERROR: the following rosdeps failed to install
homebrew: Failed to detect successful installation of [opencv]
I skip this error and I tried to build src files by using:
./src/catkin/bin/catkin_make_isolated --install -DCMAKE_BUILD_TYPE=Release
The problem is: First 8 packaged built completely but 9. package ( class_loader ) produce error:
-- catkin 0.6.11
CMake Error at CMakeLists.txt:6 (find_package):
By not providing "Findconsole_bridge.cmake" in CMAKE_MODULE_PATH this
project has asked CMake to find a package configuration file provided by
"console_bridge", but CMake did not find one.
Could not find a package configuration file provided by "console_bridge"
with any of the following names:
console_bridgeConfig.cmake
console_bridge-config.cmake
Add the installation prefix of "console_bridge" to CMAKE_PREFIX_PATH or set
"console_bridge_DIR" to a directory containing one of the above files. If
"console_bridge" provides a separate development package or SDK, be sure it
has been installed.
See also "/Users/Hakan/ros_catkin_ws/build_isolated/class_loader/CMakeFiles/CMakeOutput.log".
<== Failed to process package 'class_loader':
Command '/Users/Hakan/ros_catkin_ws/install_isolated/env.sh cmake /Users/Hakan/ros_catkin_ws/src/class_loader -DCATKIN_DEVEL_PREFIX=/Users/Hakan/ros_catkin_ws/devel_isolated/class_loader -DCMAKE_INSTALL_PREFIX=/Users/Hakan/ros_catkin_ws/install_isolated -DCMAKE_BUILD_TYPE=Release -G Unix Makefiles' returned non-zero exit status 1
Reproduce this error by running:
==> cd /Users/Hakan/ros_catkin_ws/build_isolated/class_loader && /Users/Hakan/ros_catkin_ws/install_isolated/env.sh cmake /Users/Hakan/ros_catkin_ws/src/class_loader -DCATKIN_DEVEL_PREFIX=/Users/Hakan/ros_catkin_ws/devel_isolated/class_loader -DCMAKE_INSTALL_PREFIX=/Users/Hakan/ros_catkin_ws/install_isolated -DCMAKE_BUILD_TYPE=Release -G Unix Makefiles
Command failed, exiting.
I googling for a long time but i couldn't find any solution.
any suggestion ??
Thanks...
Originally posted by heyikan on ROS Answers with karma: 11 on 2015-03-05
