this is result of catkin_make :
Base path: /home/fatima/catkin_ws1
Source space: /home/fatima/catkin_ws1/src
Build space: /home/fatima/catkin_ws1/build
Devel space: /home/fatima/catkin_ws1/devel
Install space: /home/fatima/catkin_ws1/install
#### Running command: "make cmake_check_build_system" in "/home/fatima/catkin_ws1/build"
-- Using CATKIN_DEVEL_PREFIX: /home/fatima/catkin_ws1/devel
-- Using CMAKE_PREFIX_PATH: /home/fatima/catkin_ws1/devel;/opt/ros/indigo
-- This workspace overlays: /home/fatima/catkin_ws1/devel;/opt/ros/indigo
-- Using PYTHON_EXECUTABLE: /usr/bin/python
-- Using Debian Python package layout
-- Using empy: /usr/bin/empy
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/fatima/catkin_ws1/build/test_results
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using Python nosetests: /usr/bin/nosetests-2.7
-- catkin 0.6.16
-- BUILD_SHARED_LIBS is on
-- ~~  traversing 1 packages in topological order:
-- ~~  - beginner2_tutorials
-- +++ processing catkin package: 'beginner2_tutorials'
-- ==> add_subdirectory(beginner2_tutorials)
-- Using these message generators: gencpp;genlisp;genpy
-- beginner2_tutorials: 1 messages, 1 services
CMake Error at /opt/ros/indigo/share/catkin/cmake/catkin_package.cmake:217 (message):
  catkin_package() DEPENDS on the catkin package 'nodelet' which must
  therefore be listed as a run dependency in the package.xml
  /opt/ros/indigo/share/catkin/cmake/catkin_package.cmake:98 (_catkin_package)
  beginner2_tutorials/CMakeLists.txt:13 (catkin_package)
See also "/home/fatima/catkin_ws1/build/CMakeFiles/CMakeOutput.log".
See also "/home/fatima/catkin_ws1/build/CMakeFiles/CMakeError.log".
make: *** [cmake_check_build_system] Error 1
Invoking "make cmake_check_build_system" failed
fatima@fatima-K55VD:~/catkin_ws1$ ^C
fatima@fatima-K55VD:~/catkin_ws1$ catkin_make
-- catkin 0.6.16
i think as Akif told i should bring it to the package.xml but how? i dont know
its my result when i run catkin_make again :
Base path: /home/fatima/~catkin_ws1 Source space: /home/fatima/~catkin_ws1/src Build space: /home/fatima/~catkin_ws1/build Devel space: /home/fatima/~catkin_ws1/devel Install space: /home/fatima/~catkin_ws1/install Creating symlink "/home/fatima/~catkin_ws1/src/CMakeLists.txt" pointing to "/opt/ros/indigo/share/catkin/cmake/toplevel.cmake"
Running command: "cmake /home/fatima/~catkin_ws1/src -DCATKIN_DEVEL_PREFIX=/home/fatima/~catkin_ws1/devel -DCMAKE_INSTALL_PREFIX=/home/fatima/~catkin_ws1/install -G Unix Makefiles" in "/home/fatima/~catkin_ws1/build"
-- The C compiler identification is GNU 4.8.4 -- The CXX compiler identification is GNU 4.8.4 -- Check for working C compiler: /usr/bin/cc -- Check for working C compiler: /usr/bin/cc -- works
Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Using CATKIN_DEVEL_PREFIX: /home/fatima/~catkin_ws1/devel
-- Using CMAKE_PREFIX_PATH: /opt/ros/indigo
-- This workspace overlays: /opt/ros/indigo
-- Found PythonInterp: /usr/bin/python (found version "2.7.6")
-- Using CATKIN_TEST_RESULTS_DIR: /home/fatima/~catkin_ws1/build/test_results
-- Looking for include file pthread.h
-- Looking for include file pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- catkin 0.6.16
-- Configuring done
-- Generating done
-- Build files have been written to: /home/fatima/~catkin_ws1/build
#### Running command: "make -j4 -l4" in "/home/fatima/~catkin_ws1/build"
so if it was true rosrun beginner_tutorials talker could be run is it true?
Originally posted by fatima on ROS Answers with karma: 62 on 2015-12-05
Comment by joq on 2015-12-05:
We need to see the dependencies section of you package.xml, please.
Comment by fatima on 2015-12-07:
hi sorry for these days late i have an problem , now i run catkin_make after a few days in root catkin and i receive this result , i edited my last question
i dont know is it true or not?
Comment by Akif on 2015-12-08:
@fatima, did you get any errors when you remove nodelet dependency from your CMakeLists.txt as @joq suggested?
Comment by fatima on 2015-12-08:
hi akif, no after a few days when i run catkin_make again i hadnt any error without nodelet error i was surprised i edited my answer and put the result above but yet i have the same problem i couldnt run $ rosrun beginner_tutorials talker so i dont know is the catkin_make run true or not!!!!
@fatima, in your question it is written that the package name is beginner2_tutorials not beginner_tutorials as you try. Can you check it?
yes i did that and my result is :
fatima@fatima-K55VD:~/catkin_ws1$ rosrun beginner2_tutorials talker
[rosrun] Couldn't find executable named talker below /home/fatima/catkin_ws1/src/beginner2_tutorials
i ask new question at link so thank you so much for your help
Why did you list nodelet as a CATKIN_DEPENDS in your CMakeLists.txt?
The tutorial does not do that. Try removing it.
Maybe you should start over, copying from the tutorial exactly.
Originally posted by joq with karma: 25443 on 2015-12-05
