Hi, I know that this issue is partially redundant but after days of research I cannot find any suitabel answer:
I am usung odroid C2 on Ubuntu 18.04 (3.16.65.39) from hardkernel and I am trying to compile https://github.com/robotpilot/myahrs_driver.git
When I install ros melodic exactly like described (http://wiki.ros.org/melodic/Installation/Ubuntu) I cannot "cd ~/catkin_ws && catkin_make" because there is no catkin installed! (When it was workingly installed beforehand, it gets removed by the ros-meldoc installation.
1.)When I try to (re)install catkin then by sudo apt install catkin, I get the following error message:
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information my help to resolve the situation:
The following packages have unmet dependencies:
catkin: Depends: python-catkin-pkg but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
2.) de- and reinstalling python-catkin-pkg does not change anything
3.) ros-melodic-desktop-full obviously fully depends on ros-melodic-catkin which depends on python-catkin-pkg and python-catkin-pkg-modules. The last two conflict with catkin. So how to catkin myahrs_driver?
4.) when I try to
cmake /home/user/catkin_ws/src/myahrs_driver -DATKIN_DEVEL_PREFIX=/home/user/catkin_ws/devel -DCMAHE_INSTALL_PREFIX=/home/user/catkin_ws/install -G "Unix Makefiles"
i get hte following error message:
CMake Error at CMakeLists.txt: (10) (find_package):
By not providing "Findcatkin.cmake" in CMAKE_MODULE_PATH this project has asked CMake to fing a package configuration file proviede by "cartkin", but CMake di not find one.
Could not find a package configuration file provided by "catkin" with any of the following names:
catkinConfig.cmake
catkin-config.cmake
Add the installation prefix of "catkin" to CMAKE_PREFIX_PATH or set "catkin_DIR" ro a diorectory containing on of the above files. If "catkin" provides a separate development package or SDK. be sure it has beenb installed.
--Configuring incomplete, errors occured!
5.) entering "qtcreator" and checking CMakeLists.txt from my ~catkin_ws/src directory containing "git clone https://github.com/robotpilot/myahrs_driver.git" i find:
find_packages(CATKIN REQUIRED COMPONENTS
  roscpp
  std_msgs
  sensort_msgs
  tf
Please help. Is there a possibility for your to up your compiled driver.pkg for melodic, so that I can avoid this catkin issue?
peter
Edit: @gvdhoorn: Sorry, I just tried what you suggested - if I got you right:
1.) got new plain ubuntu 18.04 image - and started from scratch,
2.) got ros-melodic-desktop-full installed without errors and
3.) sudo apt install git
4.) installed NOT catkin !
5.) "mkdir catkin_ws && cd catkin_ws" (empty)
6.) "mkdir src && cd src" then
7.) "git clone https://github.com/robotpilot/myahrs_driver.git"
8.) "cd && cd catkin_ws"
9.) cmake /home/~/catkin_ws/src/myahrs_driver -DATKIN_DEVEL_PREFIX=/home/~/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/~/catkin_ws/install -G "Unix Makefiles"
with the same error message like above again:
catkinConfig.cmake
catkin-config.cmake
Originally posted by habakuk39 on ROS Answers with karma: 3 on 2019-05-09
Comment by gvdhoorn on 2019-05-09:\
When I try to (re)install catkin then by "sudo apt install catkin"
this is most likely the cause of your problems, see wiki/UpstreamPackages.
You'll want to install ros-melodic-catkin. The catkin package is something else.
Comment by habakuk39 on 2019-05-09:
@gvdhoorn: ros-melodic-catkin is installed. It is part of ros-melodic-dektop-full
That may be, but I see you writing this:
catkin is not a package you should install. Or at least not if you want to use the packages from packages.ros.org.
The fact that you get errors complaining about catkinConfig.cmake seem to suggest that some things are not correctly installed.
If catkin is still installed (ie: the package), make sure to remove it, and any of the other packages that it depend(s)(ed) on. There are probably some Python modules that it depended on. You should remove those as well.
Finally: make sure to rm -rf $HOME/catkin_ws/build $HOME/catkin_ws/devel before trying again. CMake caches paths, so it could be that it is looking for the wrong things in the wrong locations.
@gvdhoorn: there isn't any trace of CATKIN on this image and it isnt working either! ANY help appreciated
please don't do that.
We already know that you need/want help. Otherwise you wouldn't be posting here.
I don't see you doing a source /opt/ros/melodic/setup.bash.
catkin_make is not on the PATH normally, so you need to source the setup file.
Also:
why do you do this?
For normal ROS usage this is very strange. Just run catkin_make in the root of your workspace.
I'd not recommend manually invoking cmake unless you know what you are doing.
Originally posted by gvdhoorn with karma: 86574 on 2019-05-09
@gcdhoorn: Do you know what you are?
I don't follow.
You are my genius! Thank you so much - you cannot imagine. Your help was worth a galaxy....
