I get this message after running 2.1.2 :
ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies: python_qt_binding: No definition of [python-qt-bindings] for OS [osx] qwt_dependency: No definition of [python-qt-bindings-qwt5] for OS [osx] rviz: No definition of [libqt4-opengl-dev] for OS [osx] gl_dependency: No definition of [python-qt-bindings-gl] for OS [osx] webkit_dependency: No definition of [python-qt-bindings-webkit] for OS [osx] qt_gui_cpp: No definition of [qt4-qmake] for OS [osx] qt_gui: No definition of [python-qt-bindings] for OS [osx] turtlesim: No definition of [libqt4] for OS [osx]
When I try the next step 2.1.13 ./src/catkin/bin/catkin_make_isolated --install -DCMAKE_BUILD_TYPE=Release
I get this message:
-- Using CATKIN_DEVEL_PREFIX: /Users/hector2/ros_catkin_ws/devel_isolated/catkin -- Using CMAKE_PREFIX_PATH: -- Using PYTHON_EXECUTABLE: /usr/local/bin/python -- Using default Python package layout -- Could NOT find PY_em (missing: PY_EM) CMake Error at cmake/empy.cmake:29 (message): Unable to find either executable 'empy' or Python module 'em'... try installing the package 'python-empy' Call Stack (most recent call first): cmake/all.cmake:147 (include) CMakeLists.txt:8 (include)
-- Configuring incomplete, errors occurred! See also "/Users/hector2/ros_catkin_ws/build_isolated/catkin/CMakeFiles/CMakeOutput.log". <== Failed to process package 'catkin': Command '['cmake', '/Users/hector2/ros_catkin_ws/src/catkin', '-DCATKIN_DEVEL_PREFIX=/Users/hector2/ros_catkin_ws/devel_isolated/catkin', '-DCMAKE_INSTALL_PREFIX=/Users/hector2/ros_catkin_ws/install_isolated', '-DCMAKE_BUILD_TYPE=Release', '-G', 'Unix Makefiles']' returned non-zero exit status 1
I would appreciate any help. Thanks!
Originally posted by hector_dmg on ROS Answers with karma: 1 on 2017-05-23
You issue is that the qt4 dependencies that ROS Indigo needs are no longer available. I removed them in this pull request because the Homebrew formula they mapped to were no longer available or supported:
https://github.com/ros/rosdistro/pull/14573
Unfortunately, I think ROS Indigo on macOS with Homebrew is a dead-end. Basically Homebrew has dropped support for Qt4 and despite trying to come up with all the dependencies they removed:
https://github.com/ros/homebrew-deps/pull/31
I failed to get that path to work out. At this point I think we're only going to be able to support a Qt5/Gazebo7/ROS Kinetic setup on macOS.
@mikepurvis basically came to the same conclusion:
https://github.com/mikepurvis/ros-install-osx/issues/63#issuecomment-293635361
See also:
https://github.com/ros-infrastructure/rosdep/issues/504#issuecomment-292668534
Originally posted by William with karma: 17335 on 2017-05-23
Comment by hector_dmg on 2017-05-23:
Thanks for letting me know.
