Hello,
I'm migrating a project from rosbuild to catkin, and I'm having some problems with the files using dynamic reconfigure. Currently I'm trying to make the package "controller" which contains a configuration file called dynconfig.cfg.
I followed the migration tutorial to adapt my files, so here's what I did:
- Removed
import roslib;roslib.load_manifest(PACKAGE)
in the .cfg file - Changed
from dynamic_reconfigure.parameter_generator import *
tofrom dynamic_reconfigure.parameter_generator_catkin import *
in the .cfg file - Added
generate_dynamic_reconfigure_options(cfg/dynconfig.cfg)
to my CMakeLists.txt - Added the
dynamic_reconfigure
dependencies (as run_depend and build_depend in the package.xml as well as infind_package
andcatkin_package
in the CMakeLists) - Added
add_dependencies(controller controller_controller)
in the CMakeLists. I'm not quite sure if this is right. I have an executable called controller in the package controller. However, I don't think that's where the error comes from.
Here's the error I get:
> make[2]: *** No rule to make target `/home/bic039/catkin_ws/src/controller/cfg/dynconfig.cfg', needed by `/home/bic039/catkin_ws/devel/include/controller/dynconfigConfig.h'. Stop.
Does anybody have an idea where this error might come from? I've been stuck on this issue for quite a while.
Cheers, Rob
Originally posted by Rob on ROS Answers with karma: 11 on 2013-10-10
