Hi everyone!
I'm currently migrating package per package all the nodes and stacks we've created and I'm having some trouble with catkin and dynamic reconfigure in package camera1394stereo. I've re-followed the dynamic_reconfigure tutorials in catkin mode in ros.org, but they did not help.
I have a node and a nodelet inside a package, with its corresponding "cfg" folder in it. In the CMakeLists I have
generate_dynamic_reconfigure_options(cfg/Camera1394Stereo.cfg)
before the 'catkin_package()' line, as well as the dynamic_reconfigure dependencies in both CMakeLists and package.xml.
In my machine and in the other machines we have here at work, this package compiles and works. However, when I send my package to the build farm using bloom, this is the error I get:
CMake Error at /opt/ros/groovy/share/dynamic_reconfigure/cmake/extras.cmake:47 (message):
  Could not run dynamic reconfigure file 'cfg/Camera1394Stereo.cfg': the
  rosdep view is empty: call 'sudo rosdep init' and 'rosdep update'
CMakeLists.txt:31 (generate_dynamic_reconfigure_options)
The output of the buildfarm is here
http://jenkins.willowgarage.com:8080/job/ros-groovy-camera1394stereo_sourcedeb/
I have already made some changes in the cfg file, such as removing the roslib dependecies, and I have re-checked the CMakeLists.txt, but I could not solve this. Has anyone faced this problem?
Originally posted by Miquel Massot on ROS Answers with karma: 1471 on 2013-07-29
Comment by William on 2013-07-29:
@Dirk Thomas is this a missing dependency?
The file in the repo (https://github.com/srv/camera1394stereo/blob/groovy/cfg/Camera1394Stereo.cfg#L36) indicates that it imports the old version of dynamic reconfigure intended to be used only with rosbuild:
from dynamic_reconfigure.parameter_generator import *
Please take a look at the tutorial http://www.ros.org/wiki/dynamic_reconfigure/Tutorials/HowToWriteYourFirstCfgFile describing how to write the cfg file (watch out to select catkin at the top, not rosbuild). For catkin based packages the import line is subtly different:
from dynamic_reconfigure.parameter_generator_catkin import *
Originally posted by Dirk Thomas with karma: 16276 on 2013-07-29
Comment by Miquel Massot on 2013-07-29:
Thank you! I did not notice the '_catkin' end. I've now sent a pull request with this change. It was finally built!
