Hello,
I want to use dynamic reconfiguration to modify an array in a ROS node, but I didn't found any example of how to modify the .cfg file on the web.
I want this line: gen.add("int_param", int_t, 0, "An Integer parameter", 50, 0, 100)
in something kind of: gen.add("int_array", int_t[2], 0, "An Integer array", [50 20], [0 0], [100 100])
Can someone help? Thanks!
Originally posted by TheBoris on ROS Answers with karma: 35 on 2015-07-16
According to this Tutorial, arrays are not allowed:
type - defines the type of value stored, and can be any of int_t, double_t, str_t, or bool_t
Maybe you can achieve what you want by using the group type.
Originally posted by mgruhler with karma: 12390 on 2015-07-16
Comment by TheBoris on 2015-07-16:
Sorry, but i'm a newbie, what is a group type?
Comment by mgruhler on 2015-07-16:
See the following tutorial. Maybe this gives you a hint.
