this is my client.py
#!/usr/bin/env python
PACKAGE = 'dynamic_tutorials'
import roslib;roslib.load_manifest(PACKAGE)
import rospy
import dynamic_reconfigure.client
from geometry_msgs.msg import Vector3, Twist
def callback(config):
    rospy.loginfo("Config set to {bool_param}".format(**config))
if __name__ == "__main__":
    rospy.init_node("dynamic_client")
    pub = rospy.Publisher('/turtle1/cmd_vel', Twist)
    rospy.wait_for_service("/dynamic_tutorials/set_parameters")
    tw = Twist(Vector3(1,2,0), Vector3(0,0,1))
    client = dynamic_reconfigure.client.Client("dynamic_tutorials", timeout=30, config_callback=callback)
    r = rospy.Rate(1)
    x = 0
    b = True
        x = x+1
        if x >5:
            pub.publish(tw)
            x=0
        client.update_configuration({"bool_param":b})
        r.sleep()
When i run my server.py and client.py and turtlesim_node and dynamic_reconfigure, the turtle in the turtlesim node goes in circle every 5 seconds(regardless if the bool_param in dynamic reconfigure is ticked or unticked). If i click the bool_param, it becomes unticked immediately.
Intended action: When i click on a button(bool_param, in this case is ticked) in rqt_dynamic_reconfigure , it should publish the command and remain publishing the command untill i give further instructions.
How can i implement this action? I need to control the turtle movement using dynamic_reconfigure.
Thank you!
Originally posted by Azhar on ROS Answers with karma: 100 on 2017-02-05
Comment by gvdhoorn on 2017-02-06:
Can you clarify why you want to do this with dynamic_reconfigure?
Comment by Azhar on 2017-02-06:
Basically I want an on/off button in my dynamic_reconfigure, to publish my customized data. So if the button is "on", it would publish the data.
Current problem :
  1. the button in the dynamic configure does not have any effect on the turtle when turned "on" or "off".
That sounds like a strange thing to do with dynamic_reconfigure. More something for a service. Why do you feel dynamic_reconfigure should be used for something like this?
re: no effect: well, your callback doesn't do anything besides printing the config. It doesn't update anything.
i need dynamic_reconfigure to able to change between modes for an autonomous vehicle, which is the ultimate goal. I am using turtlesim to find out how it can be done first.
Is it possible for you to guide me what i should have in my callback, to get the intended function? Any form of guide! :)
I still think this is not something you'd want to do with dynamic_reconfigure, but see amcl/src/amcl_node.cpp for how AMCL uses dyn rcfg. Mimic that in Python.
THANKS @gvdhoom!
i managed to get what i want using the dynamic_reconfigure!
General info: The config is a dictionary which stores the True/False value of the parameter. So by playing with it , you can control what you want to do!
import rospy
    global pub,tw,cw,global_name, client
    print config
    global_name = config['bool_param']
cw = Twist(Vector3(1,2,0),Vector3(0,0,-1))
   r = rospy.Rate(1)
   global_name = rospy.get_param("/dynamic_tutorials/bool_param")
   if global_name:
        pub.publish(tw)
    else:
        pub.publish(cw)
    r.sleep()
Originally posted by Azhar with karma: 100 on 2017-02-13
