Hi everyone i am stilll new here so please assist me.
So i have been trying to make a gui to change the modes(manual, teleoperation) of an vehicle from a control station.
I initially tried to do qt and tried to integrate into ROS, but i failed ;(.
I came across these rqt plugin, dynamic_reconfigure, which would able to do the same thing as my gui.
When i created the following files according to the tutorial: http://wiki.ros.org/dynamic_reconfigure/Tutorials.
These are the following problems/enquiry i have:
  1. In the section "How to Write Your First .cfg File" --> "Use the cfg File"
    #add dynamic reconfigure api #find_package(catkin REQUIRED dynamic_reconfigure) generate_dynamic_reconfigure_options( cfg/Tutorials.cfg #... )
    make sure configure headers are built before any node using them
    add_dependencies(example_node ${PROJECT_NAME}_gencfg)
What does the example_node refers to? should i change the example_node to the node which i want to change parameters/send signals?
For example, if i want to send commands to turtlesim_node, should i replace the example_node with turtlesim_node?
  1. When i compile after creating the files according to the tutorial, i get the following error.
     CMake Error at dynamic_tutorials/CMakeLists.txt:59 (add_dependencies):
     Cannot add target-level dependencies to non-existent target "example_node".
     The add_dependencies works for top-level logical targets created by the
     add_executable, add_library, or add_custom_target commands.  If you want to
     add file-level dependencies see the DEPENDS option of the add_custom_target
     and add_custom_command commands.
     See also "/home/azhar/catkin_ws/build/CMakeFiles/CMakeOutput.log".
     See also "/home/azhar/catkin_ws/build/CMakeFiles/CMakeError.log".
     make: *** [cmake_check_build_system] Error 1
     Invoking "make cmake_check_build_system" failed
Please refer below for my following folders and let me know if i am missing something
CMakeLists.txt
       project(dynamic_tutorials)
        dynamic_reconfigure
        roscpp
        rospy
        ## Generate dynamic reconfigure parameters in the 'cfg' folder
       cfg/Tutorials.cfg
         ## catkin specific configuration ##
        catkin_package(
        INCLUDE_DIRS include
         LIBRARIES dynamic_tutorials
         CATKIN_DEPENDS dynamic_reconfigure roscpp rospy
         DEPENDS system_lib
        ## Build ##
        include_directories(
         ${catkin_INCLUDE_DIRS}
        ## Declare a C++ library
        # add_library(dynamic_tutorials
        #   src/${PROJECT_NAME}/dynamic_tutorials.cpp
        ## Add cmake target dependencies of the library
        ## as an example, code may need to be generated before libraries
        ## either from message generation or dynamic reconfigure
        #add_dependencies(dynamic_tutorials ${${PROJECT_NAME}_EXPORTED_TARGETS}                       ${catkin_EXPORTED_TARGETS})
        ## Declare a C++ executable
        # add_executable(dynamic_tutorials_node src/dynamic_tutorials_node.cpp)
       ## Add cmake target dependencies of the executable
       ## same as for the library above
       # add_dependencies(dynamic_tutorials_node ${${PROJECT_NAME}_EXPORTED_TARGETS}             ${catkin_EXPORTED_TARGETS})
       ## Specify libraries to link a library or executable target against
       # target_link_libraries(dynamic_tutorials_node
       #   ${catkin_LIBRARIES}
       # make sure configure headers are built before any node using them
Tutorials.cfg
       #!/usr/bin/env python
       PACKAGE = "dynamic_tutorials"
       from dynamic_reconfigure.parameter_generator_catkin import *
       gen = ParameterGenerator()
       gen.add("int_param",    int_t,    0, "An Integer parameter", 50,  0, 100)
       gen.add("double_param", double_t, 0, "A double parameter",    .5, 0,   1)
       gen.add("str_param",    str_t,    0, "A string parameter",  "Hello World")
       gen.add("bool_param",   bool_t,   0, "A Boolean parameter",  True)
       size_enum = gen.enum([ gen.const("Small",      int_t, 0, "A small constant"),
                   gen.const("Medium",     int_t, 1, "A medium constant"),
                   gen.const("Large",      int_t, 2, "A large constant"),
                   gen.const("ExtraLarge", int_t, 3, "An extra large constant")],
                 "An enum to set size")
       gen.add("size", int_t, 0, "A size parameter which is edited via an enum", 1, 0, 3, edit_method=size_enum)
       exit(gen.generate(PACKAGE, "dynamic_tutorials", "Tutorials"))
Server.py
      import rospy
      from dynamic_reconfigure.server import Server
      from dynamic_tutorials.cfg import TutorialsConfig
      def callback(config, level):
      rospy.loginfo("""Reconfigure Request: {int_param}, {double_param},\
          {str_param}, {bool_param}, {size}""".format(**config))
      return config
      if __name__ == "__main__":
      rospy.init_node("dynamic_tutorials", anonymous = True)
      srv = Server(TutorialsConfig, callback)
      rospy.spin()
package.xml
     <?xml version="1.0"?>
     <package>
     <name>dynamic_tutorials</name>
      <version>0.0.0</version>
      <description>The dynamic_tutorials package</description>
      <maintainer email="[email protected]">azhar</maintainer>
     <license>TODO</license>
    <buildtool_depend>catkin</buildtool_depend>
    <build_depend>dynamic_reconfigure</build_depend>
    <build_depend>roscpp</build_depend>
    <build_depend>rospy</build_depend>
    <run_depend>dynamic_reconfigure</run_depend>
    <run_depend>roscpp</run_depend>
    <run_depend>rospy</run_depend>
    <export>
    </export>
    </package>
Any help would be greatly appreciated. I am using ubuntu 14.04 LTS and ROS indigo . :)
Originally posted by Azhar on ROS Answers with karma: 100 on 2017-01-15
i have solved this.
  1. example_node refers to the node, whose parameter you want to change. Ensure the name of your node and package is consistent throughout the package.
  2. latest update: https://github.com/azhar92/scooter-mode.git
Originally posted by Azhar with karma: 100 on 2017-01-21
