So I found out how to fix the warning "MSG to TF: Quaternion not properly normalized". But that does not influence the weird motion of my robot. It's still rotating in place. I guess there is somesthing wrong with the params in collvoid_params.yaml.
That is what I have done to fix the warning.
In the package collvoid_local_planner in file ROSAgent.cpp there is a function setAgentParams(). In that function the orientation will is calculated by tf::getYaw() which calls the method quaternionMsgToTF where the warning will be printed. So I normalized the quaternion myself in setAgentParams():
Before:
yaw = tf::getYaw(agent->base_odom_.pose.pose.orientation);
After:
tf::Quaternion quat(agent->base_odom_.pose.pose.orientation.x,
agent->base_odom_.pose.pose.orientation.y,
agent->base_odom_.pose.pose.orientation.z,
agent->base_odom_.pose.pose.orientation.w);
quat = quat.normalize();
yaw = tf::getYaw(quat);
Originally posted by ChrisEule with karma: 26 on 2013-08-07
Comment by bbbExtremly on 2014-01-11:
Would you mind sharing the source code of collvoid package? Because the original address is fail(rosws merge https://kforge.ros.org/collvoid/collvoid/raw-file/tip/collvoid.rosinstall) and I cannot download it. Thank you
