Hello, Everyone might think that this question is same as this article ( http://answers.ros.org/question/39347/how-to-change-global-planner-of-move_base/ ). Actually, as following the answer, I edited my move_base.launch.xml like this.
<node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
 <param name="base_global_planner" value="carrot_planner/CarrotPlanner" />
 <rosparam file="$(find turtlebot_navigation)/param/move_base_params.yaml" command="load" />
 &ltrosparam file="$(find turtlebot_navigation)/param/costmap_common_params.yaml" command="load" ns="global_costmap" />
 <rosparam file="$(find turtlebot_navigation)/param/costmap_common_params.yaml" command="load" ns="local_costmap" />
 &ltrosparam file="$(find turtlebot_navigation)/param/local_costmap_params.yaml" command="load" />
 <rosparam file="$(find turtlebot_navigation)/param/global_costmap_params.yaml" command="load" />
 &ltrosparam file="$(find turtlebot_navigation)/param/eband_planner_params.yaml" command="load" />
 <param name="base_local_planner" value="eband_local_planner/EBandPlannerROS" />
 <param name="global_costmap/map_topic" value="$(arg map_topic)" />
 <remap from="cmd_vel" to="navigation_velocity_smoother/raw_cmd_vel"/>
</node>
The result is following. As showing, Global plan set to elastic band. Elastic band is a local planner, not a global planner. My experiment environment is a turtlebot2 as a target, Hydro as ROS dist on Ubuntu 12.04.
 [ INFO] [1397253785.373263757]: Global plan set to elastic band for optimization
 [ INFO] [1397253785.374082648]: TrajectoryController: Goal reached with distance 0.00, 0.11 (od = -0.02); sending zero velocity
Could anybody tell me some information to change a global planner? Thank you in advance!
I show you an additional information. Rviz just seems to display a eband_local_planner as global & local planner. image description
Originally posted by Ken_in_JAPAN on ROS Answers with karma: 894 on 2014-04-11
Comment by Ken_in_JAPAN on 2014-04-11:
I should have read this article on this web ( http://wiki.ros.org/navigation/Tutorials/Writing%20A%20Global%20Path%20Planner%20As%20Plugin%20in%20ROS)
The reason that another planner isn't displayed on Rviz relate to yaml file?
The answer on this site ( http://answers.ros.org/question/39347/how-to-change-global-planner-of-move_base/ ) is correct. It's just adding the following code to move_base.launch.xml
< param name="base_global_planner" value="carrot_planner/CarrotPlanner" />
A way to check a change of planner is to use this command rostopic echo /move_base/parameter_updates ,but the problem of a topic in Global_Plan and Local_Plan on Rviz remains unsolved.
Originally posted by Ken_in_JAPAN with karma: 894 on 2014-04-14
Comment by hubery524 on 2019-12-11:
when I use the CarrotPlanner, there is no error,;But in rviz move_base, there is no CarrotPlanner,do you encounter this problem?
