I am trying to build ROS on a Beaglebone black. Here is the history:
12 sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu precise main" > /etc/apt/sources.list.d/ros-latest.list' 13 wget http://packages.ros.org/ros.key -O - | sudo apt-key add - 14 sudo apt-get update 15 sudo apt-get install ros-groovy-desktop or sudo apt-get install ros-groovy-ros-base
fails with:
sudo apt-get install ros-groovy-ros-base [sudo] password for ubuntu: Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package ros-groovy-ros-base
Here is the ros-latest.list: deb http://packages.ros.org/ros/ubuntu precise main
I have been successful on both amd64 and Raspberry Pi ubuntu running 12.04 Not sure what is missing here.
I note
sudo apt-get install python-rosinstall
and
sudo apt-get install build-essential python-yaml cmake subversion wget python-setuptools mercurial git-core man parted diff
worked ok.
Originally posted by DrBot on ROS Answers with karma: 147 on 2013-06-26
Comment by ccapriotti on 2014-07-15:
@DrBot, you mentioned running Ubuntu on a Raspberry PI ? AKAIK, ubuntu did not support (12.04 at least) ARM6. Have I missed something ?
