I have the following ubuntu and ros version:
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.4 LTS
Release:    16.04
Codename:   xenial
rosversion -d
kinetic
I am trying to install required packages, first I did an update:
sudo apt-get update
sudo apt-get upgrade
Then did:
sudo apt-get install ros-kinetic-joy ros-kinetic-teleop-twist-joy ros-kinetic-teleop-twist-keyboard ros-kinetic-laser-proc ros-kinetic-rgbd-launch ros-kinetic-depthimage-to-laserscan ros-kinetic-rosserial-arduino ros-kinetic-rosserial-python ros-kinetic-rosserial-server ros-kinetic-rosserial-client ros-kinetic-rosserial-msgs ros-kinetic-amcl ros-kinetic-map-server ros-kinetic-move-base ros-kinetic-urdf ros-kinetic-xacro ros-kinetic-compressed-image-transport ros-kinetic-rqt-image-view ros-kinetic-gmapping ros-kinetic-navigation ros-kinetic-interactive-markers
Reading package lists... Done
Building dependency tree
E: Unable to locate package ros-kinetic-joy
E: Unable to locate package ros-kinetic-teleop-twist-joy
E: Unable to locate package ros-kinetic-teleop-twist-keyboard
E: Unable to locate package ros-kinetic-laser-proc
E: Unable to locate package ros-kinetic-depthimage-to-laserscan
E: Unable to locate package ros-kinetic-rosserial-arduino
E: Unable to locate package ros-kinetic-rosserial-python
E: Unable to locate package ros-kinetic-rosserial-server
E: Unable to locate package ros-kinetic-rosserial-client
E: Unable to locate package ros-kinetic-rosserial-msgs
E: Unable to locate package ros-kinetic-amcl
E: Unable to locate package ros-kinetic-map-server
E: Unable to locate package ros-kinetic-move-base
E: Unable to locate package ros-kinetic-gmapping
E: Unable to locate package ros-kinetic-navigation
The content from /et/apt/sources.list.d/ros-latest.list is
  deb http://packages.ros.org/ros/ubuntu xenial main
How do I get these pacakges installed. Any help is highly appreciated!
Originally posted by engineerdream on ROS Answers with karma: 16 on 2018-03-09
Comment by nrparikh on 2018-03-09:
Did you try sudo apt-get update first before trying to install packages?
Comment by engineerdream on 2018-03-09:
yes, I did (just updated) but still have the issue
The solution I found was to remove ros completely and reinstall
sudo apt-get remove ros-*
sudo apt-get update
$ sudo apt-get upgrade
$ wget https://raw.githubusercontent.com/ROBOTIS-GIT/robotis_tools/master/install_ros_kinetic.sh && chmod 755 ./install_ros_kinetic.sh && bash ./install_ros_kinetic.sh
Originally posted by engineerdream with karma: 16 on 2018-03-09
Comment by tfoote on 2018-03-09:
That removal was likely not necessary and only removed the main packages. But rerunning the install script probably fixed your apt sources somehow.
