What I tried :
$ sudo sh -c 'echo "deb packages.ros.org/ros/ubuntu precise main" > /etc/apt/sources.list.d/ros-latest.list' $ sudo apt-get install ros-hydro-knowrob
Error : E: Unable to locate package ros-hydro-knowrob
Note sudo apt-get install ros-groovy-knowrob works fine, but I got hydro.
Originally posted by ratneshmadaan on ROS Answers with karma: 71 on 2014-03-10
KnowRob has not been released into Hydro, so it cannot be installed using apt-get. In any case, we recommend installation from source as described here http://knowrob.org/installation
Originally posted by moritz with karma: 2673 on 2014-03-10
Comment by ratneshmadaan on 2014-03-10:
Got it. Thank you.
I am getting this error now, after $ rosdep install knowrob
ERROR: Rosdep cannot find all required resources to answer your query Missing resource knowrob ROS path [0]=/opt/ros/hydro/share/ros ROS path [1]=/opt/ros/hydro/share ROS path [2]=/opt/ros/hydro/stacks
Plus, I re-installed Ubuntu 12.04 today. Gazebo is giving error as well. In mudworld, all links are not visible.
Comment by moritz on 2014-03-10:
Then your system is not set up correctly, most probably your rosbuild/catkin setup is wrong. Please try if "roscd knowrob" works, otherwise check your setup here http://wiki.ros.org/catkin/Tutorials/using_rosbuild_with_catkin
Maybe I am doing something foolish. Please help me out.
1.I made a ROS space: http://wiki.ros.org/ROS/Tutorials/InstallingandConfiguringROSEnvironment http://docs.ros.org/independent/api/rosinstall/html/rosws_ros_tutorial.html#rosws-ros-tutorial
2.rosws merge https://raw.github.com/knowrob/knowrob/master/rosinstall/knowrob-base.rosinstall rosws update rosdep install knowrob rosmake knowrob
There are two kinds of buildsystems, rosbuild and catkin. KnowRob still uses the older rosbuild, while the default in hydro is catkin. You can set up both systems to work together,you need to create a catkin WS first and then refer to it from rosbuild (Section 3.3 in the link I've posted).
Okay, Did what you said. Now keys are unresolved. :
ratneshmadaan@ratneshmadaan-Inspiron-N5010:~/rosbuild_ws$ rosdep install knowrob ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies: mod_srdl: Missing resource cmake_modules ROS path [0]=/opt/ros/hydro/share/ros ROS path [1]=/home/ratneshmadaan/rosbuild_ws/rosjava_jni ROS path [2]=/home/ratneshmadaan/rosbuild_ws/stacks/knowrob ROS path [3]=/home/ratneshmadaan/catkin_ws/devel/rosjava_jni ROS path [4]=/home/ratneshmadaan/catkin_ws/devel/stacks/knowrob ROS path [5]=/home/ratneshmadaan/catkin_ws/src ROS path [6]=/opt/ros/hydro/share ROS path [7]=/opt/ros/hydro/stacks
This is in fact a ROS dependency that you can install with apt-get install ros-hydro-cmake-modules
Comment by ratneshmadaan on 2014-03-11:
Got everything. Thanks a ton.
