I am using NAO "Osiris", NAO with laser on the head. I want to get the laser data so I can use SLAM with gmapping, etc.
How to get the laser data ?
Thanks
Update : I already solved that. I decided to not use directly but from the NaoQi SDK. But as mentioned in the answer, it is very slow.
If someone need the code, I put it here :
Hello,
I am using NAO robot right now. And I need to get the laser data, but the current NAO stack doesn't provide that. The NAO that I use is NAO with laser head. The laser is Hokuyo URG-04LX.
I want to create node which publish LaserScan topic that I get from NaoQi SDK. From the NaoQi, I can get this information :
- Min/Max Degree
- Min/Max Distance
- Array of Distance (size about : +/- 700)
Can I use that information to create the node that publish LaserScan topic ? If yes, can someone provide me the example of Hokuyo URG-04LX laser header, angle_increment, etc ?
If it is possible, I also want the example from the Hokuyo URG-04LX in the *.bag file.
Thank you :)
Update : thanks to the comment, I already can get the information via NaoQi SDK.
I put my code here, in case someone want to use it.
https://gist.github.com/rexcoder21/5957465
Originally posted by noob_coder on ROS Answers with karma: 5 on 2013-06-25
