I follow pcl recognition.
My src.
When I rosmake (full msg),it shows:
[100%] Building CXX object CMakeFiles/correspondence_grouping.dir/src/correspondence_grouping.o
/home/sam/code/ros/pcl/pcl_3d_recognition/src/correspondence_grouping.cpp:6:32: 嚴重錯誤: pcl/features/board.h:沒有此一檔案或目錄
編譯插斷。
make[3]: *** [CMakeFiles/correspondence_grouping.dir/src/correspondence_grouping.o] Error 1
make[3]: Leaving directory `/home/sam/code/ros/pcl/pcl_3d_recognition/build'
make[2]: *** [CMakeFiles/correspondence_grouping.dir/all] Error 2
make[2]: Leaving directory `/home/sam/code/ros/pcl/pcl_3d_recognition/build'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/sam/code/ros/pcl/pcl_3d_recognition/build'
Sorry for my chinese output.
I failed to change to english version output by locale.
I try to run:
export LANG=en_US
export LC_MESSAGE=en_US.UTF-8
How to fix the pcl header not found?
Thank you~
I try to download perception_pcl_fuerte_unstable.
And I passed the rosmake.
If my manifest change to :
<package>
<description brief="pcl_3d_recognition">
pcl_3d_recognition
</description>
<author>ROSfuerte</author>
<license>BSD</license>
<review status="unreviewed" notes=""/>
<url>http://ros.org/wiki/pcl_3d_recognition</url>
<depend package="roscpp"/>
<depend package="pcl16"/>
<depend package="pcl16_ros"/>
</package>
It will show the different error,but seems become very strange. Because even the basic header of first line(pcl/io/pcd_io.h) that also couldn't find.
The rosmake msg is (full msg):
/home/sam/code/ros/pcl/pcl_3d_recognition/src/correspondence_grouping.cpp:1:27: 嚴重錯誤: pcl/io/pcd_io.h:沒有此一檔案或目錄
編譯插斷。
If I change manifest to
<package>
pcl_3d_recognition
</description>
<depend package="pcl"/>
<depend package="pcl_ros"/>
</package>
It just show the first sitation of my problem I post in the beginning.
How to fix it?
Thank you~
I only change the header to
#include <pcl16/io/pcd_io.h>
#include <pcl16/point_cloud.h>
#include <pcl16/correspondence.h>
#include <pcl16/features/normal_3d_omp.h>
#include <pcl16/features/shot_omp.h>
#include <pcl16/features/board.h>
#include <pcl16/keypoints/uniform_sampling.h>
#include <pcl16/recognition/cg/hough_3d.h>
#include <pcl16/recognition/cg/geometric_consistency.h>
#include <pcl16/visualization/pcl_visualizer.h>
#include <pcl16/kdtree/kdtree_flann.h>
#include <pcl16/kdtree/impl/kdtree_flann.hpp>
#include <pcl16/common/transforms.h>
#include <pcl16/console/parse.h>
But when I rosmake, it shows (full msg):
In file included from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/point_representation.h:42:0,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/kdtree/kdtree.h:46,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/search/kdtree.h:43,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/search/pcl_search.h:44,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/features/impl/feature.hpp:43,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/features/feature.h:502,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/features/normal_3d.h:43,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/features/normal_3d_omp.h:43,
from /home/sam/code/ros/pcl/pcl_3d_recognition/src/correspondence_grouping.cpp:4:
/home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/point_types.h:56:0: 警告: ignoring #pragma warning [-Wunknown-pragmas]
/home/sam/code/ros/pcl/perception_pcl_unstable/pcl16/include/pcl-1.6/pcl16/point_types.h:590:0: 警告: ignoring #pragma warning [-Wunknown-pragmas]
/home/sam/code/ros/pcl/pcl_3d_recognition/src/correspondence_grouping.cpp:6:34: 嚴重錯誤: pcl16/features/board.h:沒有此一檔案或目錄
編譯插斷。
How to solve it?
Thank you~
I have tried pcl17.
When I rosmake it shows that vtkAppendPolyData.h not found.(the full msg)
In file included from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/common/impl/io.hpp:45:0,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/common/io.h:488,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/io/file_io.h:42,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/io/pcd_io.h:44,
from /home/sam/code/ros/pcl/pcl_3d_recognition/src/correspondence_grouping.cpp:1:
/home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/point_types.h:56:0: 警告: ignoring #pragma warning [-Wunknown-pragmas]
/home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/point_types.h:636:0: 警告: ignoring #pragma warning [-Wunknown-pragmas]
In file included from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/visualization/common/common.h:40:0,
from /home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/visualization/pcl_visualizer.h:50,
from /home/sam/code/ros/pcl/pcl_3d_recognition/src/correspondence_grouping.cpp:10:
/home/sam/code/ros/pcl/perception_pcl_unstable/pcl17/include/pcl-1.7/pcl17/visualization/vtk.h:51:31: 嚴重錯誤: vtkAppendPolyData.h:沒有此一檔案或目錄
編譯插斷。
How to solve it?
Should I post this on another thread?
And does it means that the original problem (pcl/features/board.h) is solved?
Thank you~
Originally posted by sam on ROS Answers with karma: 2570 on 2012-09-19
Comment by Boris on 2012-09-19:
According to this: http://www.pcl-users.org/3d-Object-Recognition-td3974058.html you need experimental version of pcl. So see also http://answers.ros.org/question/36837/how-to-use-current-experimental-pcl-together-with-ros-fuerte/
Comment by sam on 2012-09-20:
I have rosmake it success. But when I add dependency pcl16 and pcl16_ros, it still say the same problem. What to do next? Thank you~
Comment by Boris on 2012-09-20:
Please either remove all non-erroneous output from your question or use such services as pastebin for providing full log and source files. The text of you question is a way too long now, which makes it very difficult to read.
Comment by Boris on 2012-09-23:
Yes, I believe it is another problem. Most probably you need to install development version of VTK, if under Ubuntu try something like sudo apt-get vtk-dev
. However it is not ROS-related question, so you have to ask it on PCL forums.
