. Hi, I am trying to install ROS with PCL and compile it in ubuntu 11.10.
$svn info
Path: . URL: https://svn.pointclouds.org/ros/trunk/perception_pcl_electric_unstable Repository Root: https://svn.pointclouds.org/ros Repository UUID: 96ee21a3-c2b3-4322-a94e-acd7bc47b802 Revision: 265 Node Kind: directory Schedule: normal Last Changed Author: atrevor Last Changed Rev: 253 Last Changed Date: 2012-04-06 04:27:41 +0530 (Fri, 06 Apr 2012)
$rosmake perception_pcl_electric_unstable make[3]: Entering directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' [ 16%] Built target pcl_ros_tf Linking CXX executable ../../../bin/pcd_to_pointcloud make[3]: Entering directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' make[3]: Leaving directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' make[3]: Entering directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' Linking CXX executable ../../../bin/pointcloud_to_pcd /usr/include/boost/system/error_code.hpp:214: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:215: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:216: error: undefined reference to 'boost::system::system_category()' collect2: ld returned 1 exit status make[3]: *** [../bin/convert_pointcloud_to_image] Error 1 make[3]: Leaving directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' make[2]: *** [src/tools/CMakeFiles/convert_pointcloud_to_image.dir/all] Error 2 make[2]: *** Waiting for unfinished jobs.... /usr/include/boost/system/error_code.hpp:214: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:215: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:216: error: undefined reference to 'boost::system::system_category()' collect2: ld returned 1 exit status make[3]: *** [../bin/pointcloud_to_pcd] Error 1 make[3]: Leaving directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' make[2]: *** [src/tools/CMakeFiles/pointcloud_to_pcd.dir/all] Error 2 /usr/include/boost/system/error_code.hpp:214: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:215: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:216: error: undefined reference to 'boost::system::system_category()' collect2: ld returned 1 exit status make[3]: *** [../bin/pcd_to_pointcloud] Error 1 make[3]: Leaving directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' make[2]: *** [src/tools/CMakeFiles/pcd_to_pointcloud.dir/all] Error 2 /usr/include/boost/system/error_code.hpp:214: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:215: error: undefined reference to 'boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:216: error: undefined reference to 'boost::system::system_category()' collect2: ld returned 1 exit status make[3]: *** [../bin/convert_pcd_to_image] Error 1 make[3]: Leaving directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' make[2]: *** [src/tools/CMakeFiles/convert_pcd_to_image.dir/all] Error 2 make[2]: Leaving directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build' make[1]: *** [all] Error 2 make[1]: Leaving directory /home/swagatika/Documents/Robotic_Vision/codes/ros_workspace/perception_pcl_electric_unstable/pcl_ros/build'
[ rosmake ] Output from build of package pcl_ros written to: [ rosmake ] /home/swagatika/.ros/rosmake/rosmake_output-20120819-234013/pcl_ros/build_output.log [rosmake-0] Finished <<< pcl_ros [FAIL] [ 6.50 seconds ]
[ rosmake ] Halting due to failure in package pcl_ros. [ rosmake ] Waiting for other threads to complete.
[ rosmake ] Results:
[ rosmake ] Built 102 packages with 1 failures.
[ rosmake ] Summary output to directory
[ rosmake ] WARNING: Rosdep did not detect the following system dependencies as installed: libvtk-qt Consider using --rosdep-install option or rosdep install flann pcl pcl_ros cminpack
I have Boost 1.46.1 installed in my system.
Please help in sorting it out. Thanks.
Originally posted by swagatika on ROS Answers with karma: 1 on 2012-08-19
Hi,
It seems that the issue is with the linker which is not able to link your project to the boost directories. A quick and simple edit in your CMakelists.txt should enable the linking of the necessary boost directories.
You might have to uncomment the following line in Cmakelists:
rosbuild_add_boost_directories()
Next you will also have to add the following line:
rosbuild_link_boost(Binary_File_Name signals)
rosbuild_link_boost(Binary_File_Name systems)
Binary_File_Name is the name of the executable and the above lines have to be added after the rosbuild_add_executable() line. In most cases your rosmake should work fine after these corrections. You may search your error in Google for more information on this.
Good luck.
Originally posted by SivamPillai with karma: 612 on 2012-08-20
