I get the following error when i follow the commands from the website:
ERROR
[ 16%] Building CXX object io/CMakeFiles/pcl_io.dir/src/image_grabber.cpp.o /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp: In member function ‘bool pcl::ImageGrabberBase::ImageGrabberImpl::getCloudVTK(size_t, sensor_msgs::PointCloud2&, Eigen::Vector4f&, Eigen::Quaternionf&) const’: /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:634:34: error: no match for ‘operator=’ in ‘cloud_color.pcl::PointCloudpcl::PointXYZRGBA::header.std_msgs::Header_std::allocator<void >::stamp = timestamp’ /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:634:34: note: candidate is: /opt/ros/fuerte/include/ros/time.h:169:22: note: ros::Time& ros::Time::operator=(const ros::Time&) /opt/ros/fuerte/include/ros/time.h:169:22: note: no known conversion for argument 1 from ‘uint64_t {aka long unsigned int}’ to ‘const ros::Time&’ /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:670:28: error: no match for ‘operator=’ in ‘cloud.pcl::PointCloudpcl::PointXYZ::header.std_msgs::Header_std::allocator<void >::stamp = timestamp’ /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:670:28: note: candidate is: /opt/ros/fuerte/include/ros/time.h:169:22: note: ros::Time& ros::Time::operator=(const ros::Time&) /opt/ros/fuerte/include/ros/time.h:169:22: note: no known conversion for argument 1 from ‘uint64_t {aka long unsigned int}’ to ‘const ros::Time&’ /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp: In member function ‘bool pcl::ImageGrabberBase::ImageGrabberImpl::getCloudPCLZF(size_t, sensor_msgs::PointCloud2&, Eigen::Vector4f&, Eigen::Quaternionf&, double&, double&, double&, double&) const’: /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:765:34: error: no match for ‘operator=’ in ‘cloud_color.pcl::PointCloudpcl::PointXYZRGBA::header.std_msgs::Header_std::allocator<void >::stamp = timestamp’ /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:765:34: note: candidate is: /opt/ros/fuerte/include/ros/time.h:169:22: note: ros::Time& ros::Time::operator=(const ros::Time&) /opt/ros/fuerte/include/ros/time.h:169:22: note: no known conversion for argument 1 from ‘uint64_t {aka long unsigned int}’ to ‘const ros::Time&’ /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:810:28: error: no match for ‘operator=’ in ‘cloud.pcl::PointCloudpcl::PointXYZ::header.std_msgs::Header_std::allocator<void >::stamp = timestamp’ /home/crops_laszlo/fuerte_workspace/sandbox/pcl/io/src/image_grabber.cpp:810:28: note: candidate is: /opt/ros/fuerte/include/ros/time.h:169:22: note: ros::Time& ros::Time::operator=(const ros::Time&) /opt/ros/fuerte/include/ros/time.h:169:22: note: no known conversion for argument 1 from ‘uint64_t {aka long unsigned int}’ to ‘const ros::Time&’ make[2]: *** [io/CMakeFiles/pcl_io.dir/src/image_grabber.cpp.o] Error 1 make[1]: *** [io/CMakeFiles/pcl_io.dir/all] Error 2 make: *** [all] Error 2
Can someone understand what's the problem? Waht should I change?
Originally posted by ZsurzsaLaszlo on ROS Answers with karma: 46 on 2013-06-14
Comment by Jan_w on 2013-06-14:
It seems as if the current repository status is not being able to be build. Take a look at (not enough karma...). Google for build.pointclouds.org/overview.html
Comment by ZsurzsaLaszlo on 2013-06-24:
(karma!?) I googled but nothing usefull. Can you be more precise?
Comment by Jan_w on 2013-06-24:
I just figured out that you can directly c&p the following into the addressbar of your browser: build.pointclouds.org/overview.html then, below the login button, there is a link "login as guest". That will lead you to an overview of the buildfarm of pcl, where the status of all repos is listed.
Checkout pcl17 and pcl17_ros packages as suggested by others. Linekd the libfiles and now I get this message.
[100%] Building CXX object CMakeFiles/minitof_listener.dir/src/main.o In file included from /home/crops_laszlo/fuerte_workspace/sandbox/fuerte-unstable-devel/pcl17/include/pcl-1.7/pcl17/io/pcd_io.h:43:0,from /home/crops_laszlo/fuerte_workspace/sandbox/minitof_listener/src/main.cpp:3: /home/crops_laszlo/fuerte_workspace/sandbox/fuerte-unstable-devel/pcl17/include/pcl-1.7/pcl17/point_cloud.h:46:27: fatal error: Eigen/StdVector: No such file or directory compilation terminated.
make[2]: *** [CMakeFiles/minitof_listener.dir/src/main.o] Error 1
make[1]: *** [CMakeFiles/minitof_listener.dir/all] Error 2
Originally posted by ZsurzsaLaszlo with karma: 46 on 2013-06-25
Comment by MichaelKorn on 2013-06-25:
You need: find_package(Eigen REQUIRED) include_directories(${Eigen_INCLUDE_DIRS})
