Hi guys, I'm currently using Ubuntu 11.04 and install ROS via the source code method. I'm new and tried to play around with the erratic_robot example. When trying to do a rosmake, I came across a perception_pcl problem when compiling, the pcl folder in particular. Heres a snippet of the build_output.log:
/home/walter/ros/perception_pcl/pcl/build/pcl/build/io: ../libpcl_io.so.1.1.1: undefined reference to boost::system::system_category()' ../libpcl_io.so.1.1.1: undefined reference to boost::filesystem3::detail::status(boost::filesystem3::path const&, boost::system::error_code*)' ../libpcl_io.so.1.1.1: undefined reference to boost::system::generic_category()' collect2: ld returned 1 exit status make[3]: *** [io/tools/convert_pcd_ascii_binary] Error 1 make[3]: Leaving directory /home/walter/ros/perception_pcl/pcl/build/pcl/build' make[2]: *** [io/tools/CMakeFiles/convert_pcd_ascii_binary.dir/all] Error 2 make[2]: Leaving directory /home/walter/ros/perception_pcl/pcl/build/pcl/build' make[1]: *** [all] Error 2 make[1]: Leaving directory /home/walter/ros/perception_pcl/pcl/build/pcl/build' make: *** [installed] Error 2
Any ideas? Thanks.
Originally posted by WW on ROS Answers with karma: 86 on 2011-11-28
Hi, Pls check the version of the boost library in your system. It has to be >= 1.46.1.
Hope this helps, Karthik
Originally posted by karthik with karma: 2831 on 2011-11-28
Comment by WW on 2011-11-29:
Thanks for the response. ROS electric is set to use boost 1.42 (part of rosdep.yaml). I've installed boost 1.48 manually, however I don't know how to set ROS to use 1.48. It seems I should modify the rosdep.yaml file however I can't figure out how to do it correctly in the proper format. Thanks, WW
Comment by tfoote on 2012-04-01:
You just have to compile everything from source after upgrading boost.
