Hi,
I'm not sure of this is simply a compatibility issue or something else. On one machine I have fuerte an the other electric. Both the simple talker and listener tut's work fine with run on each machine.
I've set export ROS_MASTER_URI=http://192.168.1.40:11311 to the machine with has roscore running on.
Running roscore and talker on machine A then the listener on machine B - nothing happens. However "rosnode list" on machine A recognises lists the listener (and the listing updates when I kill the listener).
Similarly if I set up two listeners the older one gets killed off if that was running on machine B - but not the other way around.
So there seems to be some kind of comms going one. But not the whole thing.
Looking at http://www.ros.org/wiki/ROS/Tutorials/MultipleMachines hasn't reveiled anything. Pinging etc all seems okay.
Any ideas anyone?
Thanks in advance
Mark
Originally posted by MarkyMark2012 on ROS Answers with karma: 1834 on 2012-07-06
Comment by Eric Perko on 2012-07-06:
Could you update your question to include the ROS_MASTER_URI you are setting on each machine and the ROS_IP/ROS_HOSTNAME you are setting on each?
While running nodes from two different ROS distributions in the same graph may sometime work, it is definitely not supported.
Originally posted by joq with karma: 25443 on 2012-07-06
Comment by Thomas on 2012-07-07:
Exactly. This is just something you should not attempt. And maybe roscomm should issue a warning when one tries to do so.
Okay found the issue. Came down to DNS problem (Machine B is a VM and the VM network bridge was assigning it an unusual address). Updated the /etc/hosts file with the machine name where roscore is running and working as expected.
Thanks for your input all
M
Originally posted by MarkyMark2012 with karma: 1834 on 2012-07-07
