I am trying to set up a simple and listener talker across two machines connected on the same wifi network. Machine A has the 10.42.0.89 address and is running the roscore and another node that publishes messages on a topic.
$ printenv | grep ROS
ROS_IP=10.42.0.89
ROS_MASTER_URI=http://10.42.0.89:11311
The other Machine B has the ROS_MASTER_URI set to match the one of machine A
Machine B can get the list of available topics and running nodes correctly
$ rostopic list
/pose/estimate
But can't print out messages in that topic using rostopic echo /pose/estimate.
Do you have any advice?
I had this problem and I solved my problem by adding both machines' hostname to /etc/hosts. refer to https://husarion.com/tutorials/ros-tutorials/5-running-ros-on-multiple-machines/
ROS1
Machine1 [MASTER]:
  • Will run roscore, but don't run it yet till configurations are done.
  • Has an IP of 192.168.1.10.
1- Run the following in the terminal:
1.1- export ROS_MASTER_URI=http://192.168.1.10:11311.
1.2- export ROS_IP=192.168.1.10.
2- Now, run roscore.
Machine2 [SLAVE]
  • Will NOT run roscore.
  • Has and IP 192.168.1.15.
1.2- export ROS_IP=192.168.1.15.
2- Now, you are connected to the Master.
More information in the ROS 1 NetworkSetup guide
ROS2
ROS2 will populate the information on the LAN out of the box without any configuration.
By default you'll want to make sure multicast is enabled
