Hi,
A superset question is here, where it is said that we have to change the ROS_MASTER_URI to run the 2nd master.
I have tried running the 1st master with ROS_MASTER_URI=http://localhost:11311 (default), then in another terminal did the following:
$ export ROS_MASTER_URI=http://torPC2:11315/
$ echo $ROS_MASTER_URI
$ roscore
roscore cannot run as another roscore/master is already running.
Please kill other roscore/master processes before relaunching.
The ROS_MASTER_URI is http://torPC2:11311/
So, how to make roscore know that the ROS_MASTER_URI now in the 2nd terminal is http://torPC2:11315/ ? or How to run multiple roscore/master in a single machine?
My use case requires completely independent roscores/masters and even they do not need to communicate each others. Simply, it is like having multiple isolated machines with one running roscore/master in each of them.
Thanks a lot in advance.
Originally posted by tor on ROS Answers with karma: 277 on 2013-03-08
You can use the -p port option to bring up another one on a different port.
Originally posted by dornhege with karma: 31395 on 2013-03-09
Post score: 4
