Hello everyone,
I just started using ROS and had a problem with rviz.
rosrun rviz rviz
[ INFO] [1337948693.539857743]: rviz revision number 1.8.11
[ INFO] [1337948693.540013978]: compiled against OGRE version 1.7.3 (Cthugha)
Segmentation fault (core dumped)
I tried different OGRE modes:
export OGRE_RTT_MODE=Copy
export OGRE_RTT_MODE=FBO
Neither of them worked. I finally get into the bin directory of rviz and debug the exectuable. Here is the result (for the entire output, please see here):
Program received signal SIGSEGV, Segmentation fault.
0x019df739 in QMetaObject::indexOfSignal (this=0x1ad3d34, signal=0x27db89 "changed()") at /var/tmp/qt-x11-src-4.5.3/src/corelib/kernel/qmetaobject.cpp:587
587     /var/tmp/qt-x11-src-4.5.3/src/corelib/kernel/qmetaobject.cpp: No such file or directory.
And for those who are willing to help me - they say in a bug report (here) that there is a script called system_info.sh - I attach the system info here.
Thanks in advance.
Originally posted by yigit on ROS Answers with karma: 796 on 2012-05-25
Comment by dipsgautam on 2015-10-19:
Hi, I have exactly the same error except the rviz revision number is 1.8.17. Have you figured out the root cause of the issue? Thanks
Comment by gvdhoorn on 2015-10-19:
@dipsgautam: this is a very old question (Fuerte is over 5 ROS versions old), so I advise you to post a new question. Do link to this one in your new one though.
please read the page http://www.ros.org/wiki/rviz/Troubleshooting#Segfault_during_startup
and try each mode of these: copy PBuffer FBO, maybe one of them will work!
Originally posted by Barton.Qi with karma: 41 on 2012-08-24
