Hi everybody
I have problems visualizing rviz, I have installed ros in ubuntu 10.04
In one terminal I run roscore and in another terminal I run rosrun rviz rviz and I get
rviz revision number 1.6.7 ogre_tools revision number 1.6.2 compiled against OGRE version 1.7.3 (Cthugha) Loading general config from [/home/acp/.rviz/config] Loading display config from [/home/acp/.rviz/display_config] RTT Preferred Mode is PBuffer. Texture for pass 0: creating with size 1 x 1 Segmentation fault
Any clue about this segmentation fault?
In advance thank you very much
Originally posted by acp on ROS Answers with karma: 556 on 2011-11-22
well, it is a matter of giving some tries to $ rosrun rviz rviz and rviz will be lunched
problem solved :)
Originally posted by acp with karma: 556 on 2011-11-23
