I run
roslaunch openni_camera openni_node.launch
rosrun rviz rviz
I set Fixed Frame to /openni_rgb_optical_frame
I change PointCloud2's topic to /camera/rgb/points
Why rviz can't show any point cloud?
Thank you!
Originally posted by yichu on ROS Answers with karma: 42 on 2012-04-07
Comment by Eric Perko on 2012-04-07:
Yellow usually indicates that rviz hasn't received any data yet. Could you confirm that your Kinect is publishing data, say by using 'rostopic hz /camera/rgb/points'.
