I went though all relevantly tagged questions here and some tutorials, but still can't figure out what's wrong with my setup. As in subject, I'd like to configure move_base to work with gmapping
on-line - gmapping
is configured correctly, hence running. My config is mostly as described in Navigation Setup Wiki-post, ie.:
costmap_common_params.yaml
obstacle_range: 2.5
raytrace_range: 3.0
robot_radius: 0.5
inflation_radius: 0.55
observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: /laser, data_type: LaserScan, topic: /scan, marking: true, clearing: true}
global_costmap_params.yaml
global_costmap:
global_frame: /map
robot_base_frame: base_link
update_frequency: 5.0
static_map: false
local_costmap_params.yaml
local_costmap:
global_frame: world
publish_frequency: 2.0
static_map: false
rolling_window: true
width: 6.0
height: 6.0
resolution: 0.05
base_local_planner_params.yaml
TrajectoryPlannerROS:
max_vel_x: 0.1 #m/s
min_vel_x: 0.0
escape_vel: -0.1
max_rotational_vel: 0.1 #rad/s
min_in_place_rotational_vel: 0.0
y_vels: [-0.1, -0.0, 0.0, 0.1]
acc_lim_th: 1.0
acc_lim_x: 1.0 #m/s2
acc_lim_y: 1.0
holonomic_robot: true
move_base.launch
<launch>
<master auto="start"/>
<node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
<rosparam file="$(find my_robot)/costmap_common_params.yaml" command="load" ns="global_costmap" />
<rosparam file="$(find my_robot)/costmap_common_params.yaml" command="load" ns="local_costmap" />
<rosparam file="$(find my_robot)/local_costmap_params.yaml" command="load" />
<rosparam file="$(find my_robot)/global_costmap_params.yaml" command="load" />
<rosparam file="$(find my_robot)/base_local_planner_params.yaml" command="load" />
</node>
</launch>
I launch laser-scan based gmapping
before and it's all functional. I selected \world
as odom frame in all gmapping
packages, so I repeated this in move_base
as well, hope this shouldn't be a problem. In rviz I selected move_base_simple
in Tool properties -> 2D Nav Goal -> Topic. Yet, when I define a goal, nothing gets published on /cmd_vel
topic.
What else do I need? Any hints appreciated.
Originally posted by tom on ROS Answers with karma: 1079 on 2011-12-15
