Hi, I am trying to do a project on SLAM Gmapping (turtlebot2,kobuki base,ros-hydro) and I'm really blocked I need your help; actually my task is to navigate the TurtleBot and avoid obstacles and at the same time make carthographie. I follow the tutorial of stack navigation and after I realized that in that case I should not work with AMCL and map_server. So as a first step I tried to build the map,at the beginning it worked but after it didn't, I didn't know the reason, I find in rviz message: No map received. here are the steps I did: roslaunch turtlebot_bringup minimal.launch rosrun tf (laser-->base_link) rosrun tf (odom-->base_link) roslaunch turtlebot_navigation gmapping_demo.launch
the launch file of gmapping_demo.launch :
the xml file of gmapping:
<param name="delta" value="0.05"/>
<param name="llsamplerange" value="0.01"/>
<param name="llsamplestep" value="0.01"/>
<param name="lasamplerange" value="0.005"/>
<param name="lasamplestep" value="0.005"/>
<remap from="scan" to="$(arg scan_topic)"/>
the xml file of move_base:
<remap from="cmd_vel" to="navigation_velocity_smoother/raw_cmd_vel"/>
<remap from="odom" to="$(arg odom_topic)"/>
and the configuration of costmap parametrs:
costmap_common_parametrs.yaml:
obstacle_range: 2.5 raytrace_range: 3.0 robot_radius: 0.20 footprint: [[-0.16, -0.16], [-0.16, 0.16], [0.16, 0.16], [0.16, -0.16]] footprint_padding: 0.01 inflation_radius: 0.5 max_obstacle_height: 0.6 min_obstacle_height: 0.0 observation_sources: scan bump scan: {data_type: LaserScan, topic: /scan, marking: true, clearing: true} bump: {data_type: PointCloud2, topic: mobile_base/sensors/bumper_pointcloud, marking: true, clearing: false, min_obstacle_height: 0.0, max_obstacle_height: 0.15}
local_costmap_param:
local_costmap: global_frame: /odom robot_base_frame: base_link update_frequency: 5.0 publish_frequency: 2.0 static_map: false rolling_window: true width: 6.0 height: 6.0 resolution: 0.05 global_costmap_param:
globasl_costmap: global_frame: /map robot_base_frame: base_link update_frequency: 5.0 static_map: true
base_local_planner_param:
controller_frequency: 3.0 recovery_behavior_enabled: true clearing_rotation_allowed: true
TrajectoryPlannerROS: max_vel_x: 0.3 min_vel_x: 0.1 max_vel_theta: 1.0 min_vel_theta: -1.0 min_in_place_vel_theta: 0.6 acc_lim_x: 0.5 acc_lim_theta: 1.0 yaw_goal_tolerance: 0.3 xy_goal_tolerance: 0.15 sim_time: 3.0 vx_samples: 6 vtheta_samples: 20 meter_scoring: true pdist_scale: 0.6 gdist_scale: 0.8 occdist_scale: 0.01 heading_lookahead: 0.325 dwa: true oscillation_reset_dist: 0.05
holonomic_robot: false sim_granularity: 0.025 dwa: true simple_attractor: false
I await your response Thanks in advance
Originally posted by sophye_turtlebot on ROS Answers with karma: 53 on 2015-03-19
It sounds like you and I are working on nearly the same project. I am using the Pioneer3-DX and Microsoft Kinect rather than TurtleBot with laser scanner. I'll post what I have and hopefully it will help.
I followed this tutorial: Navigation - Robot Setup I also followed the video in this tutorial to help me set up RViz so I can send navigation goals to the robot and visualize him moving to the goal while building the map.
And this tutorial to build a map: Gmapping - Building a map from logged data
It looks as if you are doing everything correctly, starting your robot launch files, then your move_base.launch file.
Again, I recommend taking a look at the Navigation - Robot Setup tutorial. It is very straightforward, and while it is not specific for the Turtlebot, it should work with any robot. The turtlebot packages should take care of odometry, sensor, and tf (unless you need to add sensors) information.
I am still playing with the parameters to tune his navigation better. Long process...
Here is my move_base.launch:
<launch>
  <!-- Start gmapping -->
    <node  pkg="gmapping" name="slam_gmapping" type="slam_gmapping" output="screen" />
  <!-- Start navigation -->
    <node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
        <rosparam command="load" file="$(find follow_me_2dnav)/launch/costmap_common_params_p3dx.yaml" ns="global_costmap" />
        <rosparam command="load" file="$(find follow_me_2dnav)/launch/costmap_common_params_p3dx.yaml" ns="local_costmap" />
        <rosparam command="load" file="$(find follow_me_2dnav)/launch/local_costmap_params.yaml" />
        <rosparam command="load" file="$(find follow_me_2dnav)/launch/global_costmap_params.yaml" />
        <rosparam command="load" file="$(find follow_me_2dnav)/launch/base_local_planner_params.yaml" />
    </node>
</launch>
costmap_common_params.yaml:
obstacle_range: 4.0
raytrace_range: 5.0
footprint: [ [x1, y1], [x2, y2], [x3, y3], [x4, y4] ]
transform_tolerance: 0.5
expected_update_rate: 60
map_type: costmap
observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: kinect_depth_frame, data_type: LaserScan, topic: scan, marking: true, clearing: true, expected_update_rate: 0.2}
global_costmap_params.yaml:
global_frame: /map
update_frequency: 2.0
publish_frequency: 10.0
static_map: true
local_costmap_params.yaml:
global_frame: /odom
static_map: false
width: 7.5
height: 7.5
resolution: 0.05
  max_vel_x: 0.6
  min_vel_x: 0.1
  max_rotational_vel: 0.5
  min_in_place_rotational_vel: 0.3
  escape_vel: -0.2
  sim_time: 2.0
  path_distance_bias: 0.7
  goal_distance_bias: 0.5
  occdist_scale: 0.05
  meter_scoring: true
  acc_lim_th: 2.0
  acc_lim_x: 2.0
  acc_lim_y: 2.0
  yaw_goal_tolerance: 0.1
  xy_goal_tolerance: 0.25
Originally posted by sealguy77 with karma: 323 on 2015-03-20
Comment by sealguy77 on 2015-03-21:
Try to use comments, rather than an answer, unless you have the real answer...
You can edit your question or add updates to it instead.
I'm not sure exactly what you are looking for or the changes you made to gmapping_demo.launch. But you can find the files you need here.
The parameter files are here.
The move_base.launch.xml and gmapping.launch.xml are here.
Hope that helps.
Comment by sophye_turtlebot on 2015-03-23:
thank you very much I checked the files you sent me they look like my files but I still had the same problem I'll explain better my problem
I want build a map exactly like this tutorial: http://wiki.ros.org/turtlebot_navigation/Tutorials/Build%20a%20map%20with%20SLAM so I am writing:
roslaunch turtlebot_bringup minimal.launch roslaunch turtlebot_navigation gmapping_demo.launch roslaunch turtlebot_rviz_launchers view_navigation.launch
but what I did not understand when I "roslaunch turtlebot_navigation gmapping_demo.launch" [INFO] [1427123086.980804765]: Loading from pre-hydro parameter style [INFO] [1427123087.085777796]: Using plugin "static_layer" [INFO] [1427123087.220729356]: Requesting the map ...
as if he wait for a map while I'll build a map!! and the rviz screnn shows a warning "no map received"
Comment by sealguy77 on 2015-03-23:
Looking at the turtlebot_navigation, it does not seem like it should be looking for a map.
Try this: RViz
To make a map using teleop, I used this tutorial.
Comment by sophye_turtlebot on 2015-03-24:
apparently it's a XnSensorServer server problem, sometimes require a reboot for it to work. ust one question after having set the parameters of costmap_common_params.yaml the TurtleBot will avoid obstacles? or I need to configure this to detect and avoid obstacles?
I have added these two lines in the code that I have done in the tutorial of navigation stack for "transformation": include <costmap_2d/costmap_2d_ros.h> costmap_2d::Costmap2DROS costmap("my_costmap", tf); I found it in this in this tutorial http://wiki.ros.org/costmap_2d/hydro
But apparently it's insuffisent , i think that i must do something else for my robot to detect obstacles, have you any idea about this?
Comment by sealguy77 on 2015-03-24:
I recommend you give this Navigation tutorial a try. I followed it and the robot is able to detect and avoid obstacles as well as simultaneously build a map. I'll add my parameter files in my answer.
Also, here is additional information on costmap_2d and base_local_planner.
