Hi, I'm trying to use hectorslam in conjuction with the navigation stack for automatic map exploration. My robot has odometry and laser sensors. Hectorslam works well (with joystick teleop by exemple) but I have some problems with the navigation stack. First of all, my robot has some problem to move because some wrong obstacle detection. Here a screenshot of my rviz output that shows inflated obstacles. There is inflated obstacles in the unknown areas. I don't understand why : image description http://data.imagup.com/10/1158436086.png
Following the navigation tutorial it shouldn't have inflated obstacle in unknown spaces : image description http://www.ros.org/wiki/costmap_2d?action=AttachFile&do=get&target=costmap_rviz.png
Here, my navigation configuration files :
psykokwak@robot:~/ros/workspace$ cat arobot/config/* TrajectoryPlannerROS: max_vel_x: 0.45 min_vel_x: 0.1 max_rotational_vel: 1.0 min_in_place_rotational_vel: 0.4 acc_lim_th: 3.2 acc_lim_x: 2.5 acc_lim_y: 2.5 holonomic_robot: false meter_scoring: true obstacle_range: 2.5 raytrace_range: 3.0 footprint: [[0.2, 0.2], [0.2, -0.2], [-0.2, -0.2], [-0.2, 0.2]] inflation_radius: 0.50 observation_sources: laser_scan_sensor laser_scan_sensor: {sensor_frame: /laser, data_type: LaserScan, topic: /scan, marking: true, clearing: true} global_costmap: map_type: voxel global_frame: /map robot_base_frame: /base_link update_frequency: 1.0 static_map: true local_costmap: map_type: voxel global_frame: /odom robot_base_frame: /base_link update_frequency: 5.0 publish_frequency: 5.0 static_map: false rolling_window: true width: 3.0 height: 3.0 resolution: 0.02
An other problem I have : My computer is an Intel core i5 and the "move_base" process take 40/50%... For comparaison, the "hector_mapping" process take only 10%...
Originally posted by psykokwak on ROS Answers with karma: 65 on 2012-07-31
Comment by psykokwak on 2012-08-01:
So, the local costmap does not take care of the map provided by hector/gmapping but takes care of the map provided by the map server ? Where is the difference ?
