Hi all!
I am following this tutorial http://www.ros.org/wiki/navigation/Tutorials/RobotSetup. I am running it using stage. While I am running the move base part, I get such error:
[ WARN] [1336375509.493321469, 8.800000000]: The origin for the sensor at (4.75, 4.00, -0.43) is out of map bounds. So, the costmap cannot raytrace for it.
Hovever when I am using rviz it seams that it is able to work correctly sometimes.
Do you know any solution for this issue?
This are my yaml files:
base_local_planner_params.yaml:
TrajectoryPlannerROS: max_vel_x: 0.45 min_vel_x: 0.1 max_rotational_vel: 1.0 min_in_place_rotational_vel: 0.4
acc_lim_th: 3.2 acc_lim_x: 2.5 acc_lim_y: 2.5
holonomic_robot: true
costmap_common_params.yaml :
obstacle_range: 7.0 raytrace_range: 3.0 footprint: [[-0.7, -0.55], [-0.7, 0.55], [0.7, 0.55], [0.7, -0.55]] inflation_radius: 0.5 observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: base_laser, data_type: LaserScan, topic: base_scan, marking: true, clearing: true}
global_costmap_params.yaml :
global_costmap: global_frame: /map robot_base_frame: base_link update_frequency: 5.0 static_map: true
local_costmap_params.yaml:
local_costmap: global_frame: odom robot_base_frame: base_link update_frequency: 2.0 publish_frequency: 5.0 static_map: true rolling_window: true width: 36000.0 height: 25000.0 resolution: 0.01
Best regards Tomasz Kucner
Originally posted by tomek on ROS Answers with karma: 3 on 2012-05-07
