I tried to use the code,but failed:
- git:
uri: http://code.in.tum.de/git/cram-pl.git
local-name:cram_pl
How to fixed it?
Thank you~
sam@/home/sam/code/ros/rosinstall_auto$ rosinstall . /opt/ros/diamondback ./cram_pl.rosinstall
rosinstall operating on /home/sam/code/ros/rosinstall_auto from specifications in rosinstall files /opt/ros/diamondback, ./cram_pl.rosinstall
processing config_uri /opt/ros/diamondback
ahhhhhhhh, yaml parse error: while scanning a simple key
in "/home/sam/code/ros/rosinstall_auto/cram_pl.rosinstall", line 3, column 6
could not found expected ':'
in "/home/sam/code/ros/rosinstall_auto/cram_pl.rosinstall", line 4, column 1
Usage: rosinstall PATH [<options> ...] [URI]...
rosinstall: error: None
Originally posted by sam on ROS Answers with karma: 2570 on 2011-09-01
