Hi, I am trying to run 3d_navigation, (which the ros_wiki says is 'unreleased and contains experimental code').
  1. When I am trying to rosinstall, it is giving me following errors.
-ahhhhhhhh, yaml parse error: expected '', but found '' in "", line 6, column 19. Can anybody tell what might be missing ?
The tutorial says 'Use the following rosinstall to overlay your diamondback installation with the development versions of additional stacks and the 3d_navigation code
- svn:
    uri: https://code.ros.org/svn/wg-ros-pkg/branches/trunk_diamondback/sandbox/3d_navigation/
    local-name: stacks/3d_navigation
- svn:
    uri: https://alufr-ros-pkg.googlecode.com/svn/branches/octomap_mapping-experimental/
    local-name: stacks/octomap_mapping
- svn:
    uri: https://code.ros.org/svn/wg-ros-pkg/stacks/motion_planning_common/branches/arm_navigation_metrics
    local-name: stacks/motion_planning_common
How to use this in a rosinstall command? example please.....
-I tried to use it like:
$ rosinstall /opt/ros/diamonback https:/code.ros.org/svn/wg-ros-pkg/branches/trunk_diamondback/sandbox/3d_navigation/
(as the tutrial says: Usage: rosinstall PATH [URI] [options])
-my opt/ros/diamondback/.rosinstall file looks OK too. Here is its content
- other:
    local-name: /opt/ros/diamondback/ros
- other:
    local-name: /opt/ros/diamondback/stacks
Can anybody help me understand what is going wrong ?
Originally posted by adesh on ROS Answers with karma: 36 on 2011-06-27
Please read the rosinstall documentation.
The usage of rosinstall would be as follows:
$ rosinstall MY_DEVELOPMENT_LOCATION /opt/ros/diamondback PATH_TO_ROSINSTALL_FILE
Assuming: MY_DEVELOPMENT_LOCATION is where you want to work (usually ~/ros) . And PATH_TO_ROSINSTALL_FILE is where you saved the given rosinstall snippet into a file.
Originally posted by tfoote with karma: 58457 on 2011-06-27
