Iam trying to install rosjava with following steps.
mkdir ~/my_workspace cd ~/my_workspace rosws init rosws merge /opt/ros/groovy/.rosinstall rosws set --git --version=groovy-devel rosjava_core 'git://github.com/rosjava/rosjava_core.git' rosws update source setup.bash
Everything seems to be working fine until I run the rosws update command.It gives the error as following.
[rosjava_core] Updating /home/jhansi/my_workspace/rosjava_core WARNING [vcstools] Command failed: 'git fetch' run at: '/home/jhansi/my_workspace/rosjava_core' errcode: 128: error: RPC failed; result=56, HTTP code = 200 fatal: The remote end hung up unexpectedly fatal: early EOF fatal: index-pack failed warning: http unexpectedly said: '0000' [/vcstools] Exception caught during install: Error processing 'rosjava_core' : [rosjava_core] Update Failed of /home/jhansi/my_workspace/rosjava_core
ERROR in config: Error processing 'rosjava_core' : [rosjava_core] Update Failed of /home/jhansi/my_workspace/rosjava_core
Originally posted by Jhansi on ROS Answers with karma: 13 on 2013-05-27
Comment by HenryW on 2013-05-28:
Are you installing for ROS groovy?
