i tried to use this Github File: https://github.com/ros-drivers/um7.git i used git clone to download it, changed the CMakeLists.txt and tried the Command catkin_make. But it doesnt work i get the fatal Error back. I used already the geometry_msgs/Vector3 without problems but Vector3Stamped doesnt work... is there any Library to replace it ? or do anybody have a tip what i can Install to let it work ?
i use a Raspberry Pi4, Ubuntu 20.04 (focal) and Ros Noetic
i added the first the Error output, then the changes in the CMakeLists.txt and then the complete cpp File here :
Error if i let geometry_msgs/Vector3Stamped.h active :
/home/ubuntu/um7_driver/src/um7/src/main.cpp:37:10: fatal error: geometry_msgs/Vector3Stamped.h: No such file or directory 37 | #include "geometry_msgs/Vector3Stamped.h" | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ compilation terminated. make[2]: *** [CMakeFiles/um7_driver_2.dir/build.make:63: CMakeFiles/um7_driver_2.dir/um7/src/main.cpp.o] Error 1 make[1]: *** [CMakeFiles/Makefile2:1097: CMakeFiles/um7_driver_2.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 1%] Built target std_msgs_generate_messages_cpp [ 1%] Built target _actionlib_msgs_generate_messages_check_deps_GoalStatus [ 1%] Built target _rosserial_msgs_generate_messages_check_deps_TopicInfo make: *** [Makefile:141: all] Error 2 Invoking "make -j4 -l4" failed
Error if i comment geometry_msgs/Vector3Stamped out:
/home/ubuntu/um7_driver/src/um7/src/main.cpp:38:10: fatal error: ros/ros.h: No such file or directory 38 | #include "ros/ros.h" | ^~~~~~~~~~~ compilation terminated. make[2]: *** [CMakeFiles/um7_driver_2.dir/build.make:63: CMakeFiles/um7_driver_2.dir/um7/src/main.cpp.o] Error 1 make[1]: *** [CMakeFiles/Makefile2:1097: CMakeFiles/um7_driver_2.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 1%] Built target std_msgs_generate_messages_nodejs [ 1%] Built target _actionlib_msgs_generate_messages_check_deps_GoalID [ 1%] Built target _actionlib_msgs_generate_messages_check_deps_GoalStatusArray make: *** [Makefile:141: all] Error 2 Invoking "make -j4 -l4" failed
Changes in CMakeLists.txt :
catkin_workspace()
include_directories( ${catkin_INCLUDE_DIRS})
add_executable( um7_driver_2 /home/ubuntu/um7_driver/src/um7/src/main.cpp ) target_link_libraries( um7_driver_2 ${catkin_LIBRARIES} )
the new CMakeLists.txt:
cmake_minimum_required(VERSION 2.8.3) project(um7_test)
find_package(catkin REQUIRED COMPONENTS roscpp serial sensor_msgs message_generation)
add_service_files( FILES Reset.srv )
generate_messages()
catkin_package( INCLUDE_DIRS include CATKIN_DEPENDS message_runtime )
Build
Specify additional locations of header files
Your package locations should be listed before other locations
include_directories(include ${catkin_INCLUDE_DIRS} )
Declare a cpp executable
add_executable(um7_driver src/main.cpp src/registers.cpp src/comms.cpp) target_link_libraries(um7_driver ${catkin_LIBRARIES} ) add_dependencies(um7_driver um7_generate_messages_cpp)
Install
install(TARGETS um7_driver RUNTIME DESTINATION ${CATKIN_PACKAGE_BIN_DESTINATION} )
Testing
############# if(CATKIN_ENABLE_TESTING) find_package(roslint REQUIRED) catkin_add_gtest(${PROJECT_NAME}_test_registers test/test_registers.cpp src/registers.cpp) catkin_add_gtest(${PROJECT_NAME}_test_comms test/test_comms.cpp src/comms.cpp src/registers.cpp) target_link_libraries(${PROJECT_NAME}_test_comms util ${catkin_LIBRARIES})
file(GLOB LINT_SRCS src/*.cpp include/um7/registers.h include/um7/comms.h) roslint_cpp(${LINT_SRCS}) roslint_add_test() endif()
Complete cpp File main.cpp:
  • \file
  • \brief Main entry point for UM7 driver. Handles serial connection
  •          details, as well as all ROS message stuffing, parameters,
  •          topics, etc.
  • \author Mike Purvis [email protected] (original code for UM6)
  • \copyright Copyright (c) 2013, Clearpath Robotics, Inc.
  • \author Alex Brown [email protected] (adapted to UM7)
  • \copyright Copyright (c) 2015, Alex Brown.
*/ #include #include "geometry_msgs/Vector3Stamped.h" #include <ros/ros.h> #include "sensor_msgs/Imu.h" #include "sensor_msgs/MagneticField.h" #include "serial/serial.h" #include "std_msgs/Float32.h" #include "std_msgs/Header.h" #include "um7/comms.h" #include "um7/registers.h" #include "um7/Reset.h"
const char VERSION[10] = "0.0.2"; // um7_driver version
// Don't try to be too clever. Arrival of this message triggers // us to publish everything we have. const uint8_t TRIGGER_PACKET = DREG_EULER_PHI_THETA;
namespace OutputAxisOptions { enum OutputAxisOption { DEFAULT, ENU, ROBOT_FRAME }; } typedef OutputAxisOptions::OutputAxisOption OutputAxisOption;
  • Function generalizes the process of writing an XYZ vector into consecutive
  • fields in UM7 registers. / template void configureVector3(um7::Comms sensor, const um7::Accessor& reg, std::string param, std::string human_name) { if (reg.length != 3) { throw std::logic_error("configureVector3 may only be used with 3-field registers!"); }
if (ros::param::has(param)) { double x, y, z; ros::param::get(param + "/x", x); ros::param::get(param + "/y", y); ros::param::get(param + "/z", z); ROS_INFO_STREAM("Configuring " << human_name << " to (" << x << ", " << y << ", " << z << ")"); reg.set_scaled(0, x); reg.set_scaled(1, y); reg.set_scaled(2, z); if (sensor->sendWaitAck(reg)) { throw std::runtime_error("Unable to configure vector."); } } }
  • Function generalizes the process of commanding the UM7 via one of its command
  • registers. / template void sendCommand(um7::Comms sensor, const um7::Accessor& reg, std::string human_name) { ROS_INFO_STREAM("Sending command: " << human_name); if (!sensor->sendWaitAck(reg)) { throw std::runtime_error("Command to device failed."); } }
  • Send configuration messages to the UM7, critically, to turn on the value outputs
  • which we require, and inject necessary configuration parameters. / void configureSensor(um7::Comms sensor, ros::NodeHandle *private_nh) { um7::Registers r;
uint32_t comm_reg = (BAUD_115200 << COM_BAUD_START); r.communication.set(0, comm_reg); if (!sensor->sendWaitAck(r.comrate2)) { throw std::runtime_error("Unable to set CREG_COM_SETTINGS."); }
// set the broadcast rate of the device int rate; private_nh->param("update_rate", rate, 20); if (rate < 20 || rate > 255) { ROS_WARN("Potentially unsupported update rate of %d", rate); }
uint32_t rate_bits = static_cast<uint32_t>(rate); ROS_INFO("Setting update rate to %uHz", rate); uint32_t raw_rate = (rate_bits << RATE2_ALL_RAW_START); r.comrate2.set(0, raw_rate); if (!sensor->sendWaitAck(r.comrate2)) { throw std::runtime_error("Unable to set CREG_COM_RATES2."); }
uint32_t proc_rate = (rate_bits << RATE4_ALL_PROC_START); r.comrate4.set(0, proc_rate); if (!sensor->sendWaitAck(r.comrate4)) { throw std::runtime_error("Unable to set CREG_COM_RATES4."); }
uint32_t misc_rate = (rate_bits << RATE5_EULER_START) | (rate_bits << RATE5_QUAT_START); r.comrate5.set(0, misc_rate); if (!sensor->sendWaitAck(r.comrate5)) { throw std::runtime_error("Unable to set CREG_COM_RATES5."); }
uint32_t health_rate = (5 << RATE6_HEALTH_START); // note: 5 gives 2 hz rate r.comrate6.set(0, health_rate); if (!sensor->sendWaitAck(r.comrate6)) { throw std::runtime_error("Unable to set CREG_COM_RATES6."); }
// Options available using parameters) uint32_t misc_config_reg = 0; // initialize all options off
// Optionally disable mag updates in the sensor's EKF. bool mag_updates; private_nh->param("mag_updates", mag_updates, true); if (mag_updates) { misc_config_reg |= MAG_UPDATES_ENABLED; } else { ROS_WARN("Excluding magnetometer updates from EKF."); }
// Optionally enable quaternion mode . bool quat_mode; private_nh->param("quat_mode", quat_mode, true); if (quat_mode) { misc_config_reg |= QUATERNION_MODE_ENABLED; } else { ROS_WARN("Excluding quaternion mode."); }
r.misc_config.set(0, misc_config_reg); if (!sensor->sendWaitAck(r.misc_config)) { throw std::runtime_error("Unable to set CREG_MISC_SETTINGS."); }
// Optionally disable performing a zero gyros command on driver startup. bool zero_gyros; private_nh->param("zero_gyros", zero_gyros, true); if (zero_gyros) sendCommand(sensor, r.cmd_zero_gyros, "zero gyroscopes"); }
bool handleResetService(um7::Comms* sensor, const um7::Reset::Request& req, const um7::Reset::Response& resp) { um7::Registers r; if (req.zero_gyros) sendCommand(sensor, r.cmd_zero_gyros, "zero gyroscopes"); if (req.reset_ekf) sendCommand(sensor, r.cmd_reset_ekf, "reset EKF"); if (req.set_mag_ref) sendCommand(sensor, r.cmd_set_mag_ref, "set magnetometer reference"); return true; }
  • Uses the register accessors to grab data from the IMU, and populate
  • the ROS messages which are output. / void publishMsgs(um7::Registers& r, ros::NodeHandle imu_nh, sensor_msgs::Imu& imu_msg, OutputAxisOption axes, bool use_magnetic_field_msg) { static ros::Publisher imu_pub = imu_nh->advertise<sensor_msgs::Imu>("data", 1, false); static ros::Publisher mag_pub; ////////////////////////////////////////////////////////////////////////////////////////// if (use_magnetic_field_msg) { mag_pub = imu_nh->advertise<sensor_msgs::MagneticField>("mag", 1, false); } else { cout<<"Vector3Stamped"; mag_pub = imu_nh->advertise<geometry_msgs::Vector3Stamped>("mag", 1, false); } ///////////////////////////////////////////////////////////////////////////////////////////
    static ros::Publisher rpy_pub = imu_nh->advertise<geometry_msgs::Vector3Stamped>("rpy", 1, false); static ros::Publisher temp_pub = imu_nh->advertise<std_msgs::Float32>("temperature", 1, false);
if (imu_pub.getNumSubscribers() > 0) { switch (axes) { case OutputAxisOptions::ENU: { // body-fixed frame NED to ENU: (x y z)->(x -y -z) or (w x y z)->(x -y -z w) // world frame NED to ENU: (x y z)->(y x -z) or (w x y z)->(y x -z w) // world frame imu_msg.orientation.w = r.quat.get_scaled(2); imu_msg.orientation.x = r.quat.get_scaled(1); imu_msg.orientation.y = -r.quat.get_scaled(3); imu_msg.orientation.z = r.quat.get_scaled(0);
    // body-fixed frame
    imu_msg.angular_velocity.x =  r.gyro.get_scaled(0);
    imu_msg.angular_velocity.y = -r.gyro.get_scaled(1);
    imu_msg.angular_velocity.z = -r.gyro.get_scaled(2);
    // body-fixed frame
    imu_msg.linear_acceleration.x =  r.accel.get_scaled(0);
    imu_msg.linear_acceleration.y = -r.accel.get_scaled(1);
    imu_msg.linear_acceleration.z = -r.accel.get_scaled(2);
    break;
  case OutputAxisOptions::ROBOT_FRAME:
    // body-fixed frame
    imu_msg.orientation.w = -r.quat.get_scaled(0);
    imu_msg.orientation.x = -r.quat.get_scaled(1);
    imu_msg.orientation.y =  r.quat.get_scaled(2);
    imu_msg.orientation.z =  r.quat.get_scaled(3);
    // body-fixed frame
    // body-fixed frame
    break;
  case OutputAxisOptions::DEFAULT:
    imu_msg.orientation.w = r.quat.get_scaled(0);
    imu_msg.angular_velocity.y = r.gyro.get_scaled(1);
    imu_msg.angular_velocity.z = r.gyro.get_scaled(2);
    imu_msg.linear_acceleration.y = r.accel.get_scaled(1);
    imu_msg.linear_acceleration.z = r.accel.get_scaled(2);
    break;
  default:
    ROS_ERROR("OuputAxes enum value invalid");
imu_pub.publish(imu_msg);
// Magnetometer. transform to ROS axes ///////////////////////////////////////////////////////////////////////////////// if (mag_pub.getNumSubscribers() > 0) { if (use_magnetic_field_msg) { sensor_msgs::MagneticField mag_msg; mag_msg.header = imu_msg.header;
  switch (axes)
      mag_msg.magnetic_field.x = r.mag.get_scaled(1);
      mag_msg.magnetic_field.y = r.mag.get_scaled(0);
      mag_msg.magnetic_field.z = -r.mag.get_scaled(2);
      break;
      // body-fixed frame
      mag_msg.magnetic_field.x =  r.mag.get_scaled(0);
      mag_msg.magnetic_field.y = -r.mag.get_scaled(1);
      break;
      mag_msg.magnetic_field.y = r.mag.get_scaled(1);
      mag_msg.magnetic_field.z = r.mag.get_scaled(2);
      break;
    default:
  mag_pub.publish(mag_msg);
else
  geometry_msgs::Vector3Stamped mag_msg;
  switch (axes)
      mag_msg.vector.x = r.mag.get_scaled(1);
      mag_msg.vector.y = r.mag.get_scaled(0);
      mag_msg.vector.z = -r.mag.get_scaled(2);
      break;
      // body-fixed frame
      mag_msg.vector.x =  r.mag.get_scaled(0);
      mag_msg.vector.y = -r.mag.get_scaled(1);
      break;
      mag_msg.vector.y = r.mag.get_scaled(1);
      mag_msg.vector.z = r.mag.get_scaled(2);
      break;
    default:
// Euler attitudes. transform to ROS axes if (rpy_pub.getNumSubscribers() > 0) { geometry_msgs::Vector3Stamped rpy_msg; rpy_msg.header = imu_msg.header;
switch (axes)
    // world frame
    rpy_msg.vector.x = r.euler.get_scaled(1);
    rpy_msg.vector.y = r.euler.get_scaled(0);
    rpy_msg.vector.z = -r.euler.get_scaled(2);
    break;
    rpy_msg.vector.x =  r.euler.get_scaled(0);
    rpy_msg.vector.y = -r.euler.get_scaled(1);
    break;
    rpy_msg.vector.y = r.euler.get_scaled(1);
    rpy_msg.vector.z = r.euler.get_scaled(2);
    break;
  default:
rpy_pub.publish(rpy_msg);
// Temperature if (temp_pub.getNumSubscribers() > 0) { std_msgs::Float32 temp_msg; temp_msg.data = r.temperature.get_scaled(0); temp_pub.publish(temp_msg); } }
  • Node entry-point. Handles ROS setup, and serial port connection/reconnection. */ int main(int argc, char **argv) { ros::init(argc, argv, "um7_driver");
// Load parameters from private node handle. std::string port; int32_t baud;
ros::NodeHandle imu_nh("imu"), private_nh("~"); private_nh.paramstd::string("port", port, "/dev/ttyUSB0"); private_nh.param<int32_t>("baud", baud, 115200);
serial::Serial ser; ser.setPort(port); ser.setBaudrate(baud); serial::Timeout to = serial::Timeout(50, 50, 0, 50, 0); ser.setTimeout(to);
sensor_msgs::Imu imu_msg; double linear_acceleration_stdev, angular_velocity_stdev; private_nh.paramstd::string("frame_id", imu_msg.header.frame_id, "imu_link"); // Defaults obtained experimentally from hardware, no device spec exists private_nh.param("linear_acceleration_stdev", linear_acceleration_stdev, (4.0 * 1e-3f * 9.80665)); private_nh.param("angular_velocity_stdev", angular_velocity_stdev, (0.06 * 3.14159 / 180.0));
double linear_acceleration_cov = linear_acceleration_stdev * linear_acceleration_stdev; double angular_velocity_cov = angular_velocity_stdev * angular_velocity_stdev;
// From the UM7 datasheet for the dynamic accuracy from the EKF. double orientation_x_stdev, orientation_y_stdev, orientation_z_stdev; private_nh.param("orientation_x_stdev", orientation_x_stdev, (3.0 * 3.14159 / 180.0)); private_nh.param("orientation_y_stdev", orientation_y_stdev, (3.0 * 3.14159 / 180.0)); private_nh.param("orientation_z_stdev", orientation_z_stdev, (5.0 * 3.14159 / 180.0));
double orientation_x_covar = orientation_x_stdev * orientation_x_stdev; double orientation_y_covar = orientation_y_stdev * orientation_y_stdev; double orientation_z_covar = orientation_z_stdev * orientation_z_stdev;
// Enable converting from NED to ENU by default bool tf_ned_to_enu; bool orientation_in_robot_frame; private_nh.param("tf_ned_to_enu", tf_ned_to_enu, true); private_nh.param("orientation_in_robot_frame", orientation_in_robot_frame, false); OutputAxisOption axes = OutputAxisOptions::DEFAULT; if (tf_ned_to_enu && orientation_in_robot_frame) { ROS_ERROR("Requested IMU data in two separate frames."); } else if (tf_ned_to_enu) { axes = OutputAxisOptions::ENU; } else if (orientation_in_robot_frame) { axes = OutputAxisOptions::ROBOT_FRAME; }
// Use MagneticField message rather than Vector3Stamped. bool use_magnetic_field_msg; private_nh.param("use_magnetic_field_msg", use_magnetic_field_msg, false);
// These values do not need to be converted imu_msg.linear_acceleration_covariance[0] = linear_acceleration_cov; imu_msg.linear_acceleration_covariance[4] = linear_acceleration_cov; imu_msg.linear_acceleration_covariance[8] = linear_acceleration_cov;
imu_msg.angular_velocity_covariance[0] = angular_velocity_cov; imu_msg.angular_velocity_covariance[4] = angular_velocity_cov; imu_msg.angular_velocity_covariance[8] = angular_velocity_cov;
imu_msg.orientation_covariance[0] = orientation_x_covar; imu_msg.orientation_covariance[4] = orientation_y_covar; imu_msg.orientation_covariance[8] = orientation_z_covar;
// Real Time Loop bool first_failure = true; while (ros::ok()) { try { ser.open(); } catch (const serial::IOException& e) { ROS_WARN("um7_driver was unable to connect to port %s.", port.c_str()); } if (ser.isOpen()) { ROS_INFO("um7_driver successfully connected to serial port %s.", port.c_str()); first_failure = true; try { um7::Comms sensor(&ser); configureSensor(&sensor, &private_nh); um7::Registers registers; ros::ServiceServer srv = imu_nh.advertiseService<um7::Reset::Request, um7::Reset::Response>( "reset", boost::bind(handleResetService, &sensor, _1, _2));
    while (ros::ok())
      // triggered by arrival of last message packet
      if (sensor.receive(&registers) == TRIGGER_PACKET)
        // Triggered by arrival of final message in group.
        imu_msg.header.stamp = ros::Time::now();
        publishMsgs(registers, &imu_nh, imu_msg, axes, use_magnetic_field_msg);
        ros::spinOnce();
  catch(const std::exception& e)
    if (ser.isOpen()) ser.close();
    ROS_ERROR_STREAM(e.what());
    ROS_INFO("Attempting reconnection after error.");
    ros::Duration(1.0).sleep();
else
  ROS_WARN_STREAM_COND(first_failure, "Could not connect to serial device "
                       << port << ". Trying again every 1 second.");
  first_failure = false;
} }whole
Originally posted by Fxaxo on ROS Answers with karma: 3 on 2021-07-02
Comment by photon on 2021-07-03:
Could you include the compilation log, and the changes that was made in the CMakeLists.txt?
Comment by Mike Scheutzow on 2021-07-03:
@Fxaxo: Some friendly advice: you need to pay more attention to the format of file names: the first letter of geometry_msgs is not capitialized, and the first letter of Vector3Stamped.h is capitalized.
Comment by Mike Scheutzow on 2021-07-05:
@Fxaxo Please don't create an "answer" unless you are telling us what the solution to the title of this post is. Additional information like you posted below should be added as a comment (like this one.) Please delete that answer and instead put the new info into a comment.
The line in which you include ros.h is not valid c. Also, please show us the exact text of the error from catkin_make.
Comment by Fxaxo on 2021-07-05:
oh okaz i understand ! okaz i postet the error output in the question. i already tried to install some sudo apt-get plug ins like ros-roscpp-msg to work with the ros library but it still not work... also with the geometry_msgs i installed already the ros-geometry-msgs
I suspect you are missing required lines in CMakeLists.txt. Have you provided lines with the necessary roscpp info? There are many, many examples of CMakeLists.txt for you to look at.
hm i compared my CMakeLists to many others who using the lib ros/ros.h and i didnt found anything wrong ... i added the complete CMakeList like i have it in the question can u have a look on it and maybe see whats missing ?
Your CMakeLists.txt file does not look like any I have ever seen for a ROS1 package. You really need to find one from a package that actually compiles and use it as a reference for your own project.
Comment by Fxaxo on 2021-07-06:
oh okay i will search and keep u updated when i find the solution ! thank you ! @Mike Scheutzow
Comment by Fxaxo on 2021-07-08:
i found a CMakeLists.txt wich i copied and configured for my Project do this fit more in the regular CMakeLists ?
i added the new file in the question
Comment by Mike Scheutzow on 2021-07-08:
That CMakeLists.txt still looks incomplete to me. Have you tried looking at any of the roscpp tutorials? For example, this one:
http://wiki.ros.org/roscpp_tutorials/Tutorials/WritingPublisherSubscriber
Make sure you get a clean build by deleting the top-level devel and lib directories in catkin_ws dir if you make big changes to CMakeLists.txt, or old broken stuff tends to get "remembered".
Comment by 404RobotNotFound on 2021-07-08:
As a side note, you can highlight your text and use Ctrl + k to format it as code and make it a lot more readable and not get caught in markdown formatting
You need to create a valid CMakeLists.txt file. For an example, take a look at http://wiki.ros.org/roscpp_tutorials/Tutorials/WritingPublisherSubscriber
Originally posted by Mike Scheutzow with karma: 4903 on 2021-07-08
This is probably the more correct solution after you have dug deeper into the issue. Even the code linked in the initial question (https://github.com/ros-drivers/um7) is a good enough example to follow
