Hi everybody, I am trying a global planner based on D* lite. I am using launch files in sbpl_lattice_planner. But move_base dies as soon as goal is passed through nav_view! The problem is how to run this complete setup in gdb as there are multiple executables involved and roslaunch do a lot of things. Parameters can be set using rosparam, but How I can run a node in some namespace in gdb ?
The part of launch file look like this:
thanks prince
Originally posted by prince on ROS Answers with karma: 660 on 2011-08-08
Not sure about the namespace thing, but to launch a node in gdb you usually add the launch-prefix attribute to the node tag like this:
<node launch-prefix="gdb -ex run --args" .../>
Did you try that already?
See also here
Originally posted by LiMuBei with karma: 261 on 2011-08-08
