Hey everybody,
I'm still working on my platform which is already running in the meantime. But I had to do some workarounds. To be more precise i didn't manged to set up the move_base to work with my bot. Either it is the setup/params or the odometry (which i programmed myself). But the Pathfinding works so far. So i programmed a path executor. A node, that just follows the path (the green line from the (global?) planner - NAVfn_path). No local planner, nothing extra. Just try to follow this line as close as possible. The bot is really slow - no dynamics to take into account. Moving objects are avoided because the path gets recalculated once every second or so.
Now to the "problem": i want to get rid of all the unneeded code running inside of move_base. So i tried to set up a costmap (costmap_2d) with the parameters i used with the move_base (since the costmap there just looks nice as it is right now :D). The standalone costmap looks as expected in rviz. Next step would be to start the "global_planner". from this link it is doing everything i need. I can even change the type of calculation there. And i hope i can just reinit the planner once it dies because the goal lies within an obstacle (the move_base tends to do this. The carrot_planner would do what i need, but ignores obstacles at all - even walls). But ... how do i call the planner? I just tried
$ rosrun glob[tab]al_planner [tab]planner
the [tab] just auto completed the command. So i would expect the node exists. I added it to the launch file i had prepared and it worked. for the goal i used
$ rostopic pub /planner/goal geometry_msgs/PoseStamped '{header: {frame: map}, pose: {position: {x: 1.0, y: 2.0, z: 0.0}}}'
Well, the planner complained the bot is outside of it's costmap. So i displayed it in rviz. And yes, it's outside, or more resize at 0.0/0.0 . And the costmap is blank. The costmap from the costmap_2d-node looks still nice and the bot is at the correct position (amcl works fine).
==>> How do i tell the "global_planner" to use the costmap of the "costmap_2d" ?
the documentation doesn't name anything like this. No topic the node subscribes to or a parameter with the name. all in all the documentation seems to be limited to the minimum since the planner doesn't seem to be intended to be used outside of move_base at all ?
rosparam list:
/costmap_2d_node/costmap/(many different parameters here)
/planner/costmap/(almost the same parameters as above)
Launchfile (shorted/abstract):
<launch>
    <include> hardware driver, laserscanner, encoder, odometry </include>
    <node> map server </node>
    <node> amcl </node>
    <node pkg="costmap_2d" type="costmap_2d_node" name="costmap_2d_node" clear_params="true">
        <rosparam file="$(find navigation)nav_config/params.yaml" />
    </node>
    <node pkg="global_planner" type="planner" name="planner" />
    <robotdescription> my own xacro </robotdescription>
    <robot_state_publisher ... />
    <joint_state_publisher ... />
    <node> rviz </node>
</launch>
params.yaml (but since the costmap itself looks nice i expect it to be ok):
costmap:
    map_type: costmap
    global_frame: /map
    robot_base_frame: /base_link
    update_frequency: 5.0
    publish_frequency: 2.0
    static_map: true
    rolling_window: false
    resolution: 0.1
    obstacle_range: 2.5
    raytrance_range: 5.0
    inflation_radius: 0.9
    observation_sources: laser_scan
Originally posted by -LD- on ROS Answers with karma: 135 on 2018-10-05
And i would like to answer my own question. it came to me as i wrote down that the two nodes have almost exactly the same costmap/params. The global_planner just comes with it's own costmap. All i had to do is to load the exact same yaml-file together with the global_planner. And as expected: the node complains and doesn't calculate a path, but it stays alive and you can just enter a valid goal and the planner will than give you a plan.
Maybe this can help someone trying the same as me :D
Originally posted by -LD- with karma: 135 on 2018-10-05
