when i run "sudo apt-get install ros-diamondback-openni-kinect", i get the following message:
Reading package lists... Done Building dependency tree
Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: ros-diamondback-openni-kinect : Depends: nite-dev but it is not going to be installed E: Broken packages
Can anyone help?? Thx in advance..
Originally posted by Rorsak on ROS Answers with karma: 11 on 2011-05-21
Comment by Mac on 2011-05-23:
Can you give us more information? Which version of ROS are you installing? What sort of system are you installing it on? Version numbers will help us, here.
I solved the problem by running
sudo aptitude install ros-diamondback-openni-kinect
It lets you choose how to resolve these dependencies.
Originally posted by Susanne Thierfelder with karma: 26 on 2011-05-28
