Hello,
I am not able to install openni package on hydro. Is there any workaround? Since i could see it is not available for the hydro disto.
sudo apt-get install ros-hydro-openni2-camera
[sudo] password for rootx:
Reading package lists... Done
Building dependency tree
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 313 not upgraded.
Need to get 441 kB of archives.
After this operation, 0 B of additional disk space will be used.
Err http://packages.ros.org/ros/ubuntu/ raring/main ros-hydro-openni2-camera i386 0.1.2-0raring-20140311-1903-+0000 404 Not Found
Failed to fetch http://packages.ros.org/ros/ubuntu/pool/main/r/ros-hydro-openni2-camera/ros-hydro-openni2-camera_0.1.2-0raring-20140311-1903-+0000_i386.deb 404 Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
-Abhimoh
Originally posted by Prasad on ROS Answers with karma: 79 on 2014-04-09
As suggested in the error message, you should try a sudo apt-get update first. The package it's trying to download is no longer available, there is a newer version instead.
Originally posted by Martin Günther with karma: 11816 on 2014-04-10
