I'm trying to install the hydro turtlebot simulator on Ubuntu 12.04 (32 bit) but the dependencies for openni seem a bit wacky. I've installed and uninstalled a few times now and nothing seems to work. It seems to boil down to ros-hydro-openni-launch refuses to install because it doesn't want to install ros-hydro-openni-camera even if ros-hydro-openni-camera is already installed.
The following packages have unmet dependencies:
 ros-hydro-turtlebot-bringup : Depends: ros-hydro-openni-launch but it is not going to be installed
 ros-hydro-openni-launch : Depends: ros-hydro-openni-camera but it is not going to be installed
ros-hydro-openni-camera is already the newest version.
If I have ros-hydro-openni-camera installed, and then do an "apt-get install ros-hydro-desktop-full", it removes ros-hydro-openni-camera, e.g.
Removing ros-hydro-openni-camera ...
Removing libopenni-dev ...
Removing libopenni-sensor-primesense-dev ...
Removing libopenni-sensor-primesense0 ...
Removing openni-utils ...
Removing libopenni0 ...
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
Processing triggers for man-db ...
Selecting previously unselected package openni-dev.
...and I'm back at square one.
I'm guessing there's a conflict between openni-dev and libopenni-dev Any suggestions as to how to get things installed properly?
Thanks, -Mark
Originally posted by mallanmba on ROS Answers with karma: 46 on 2013-09-04
Thanks, all looks good now. For those who were experiencing this problem, do the following:
sudo apt-get update
sudo apt-get dist-upgrade
...then install your ros debs
Originally posted by mallanmba with karma: 46 on 2013-09-05
Comment by tfoote on 2013-09-05:
Please accept the answer so people know your problem is solved.
Comment by pmolina on 2014-01-30:
this did not really worked for me. Please check my problem http://answers.ros.org/question/115546/cannot-install-ros-hydro-on-ubuntu-1204/
