Hi there!
I'm having a problem when I launch RVIZ with a join_state_publisher. For exemple, when I do the tutorial from this page (Building Movable Robot Model with URDF) and I close it.
When I execute roswtf, appears that message:
"ERROR: Could not contact the following nodes: * /joint_state_publisher"
If I try to kill them with rosnode kill /joint_state_publisher it seem's that be OK, but if I rerun it I gave the same message.
I think that this is important because in next reruns of RVIZ it doesn't works correctly (the model not appears completly).
Any idea?
Originally posted by mbj on ROS Answers with karma: 197 on 2011-03-08
Finally think that I solved the problem.
I forgot to add in my launch file the correct path for the joint_state_publisher and set the gui parameter to true.
Finally, my launch file looks like this:
Originally posted by mbj with karma: 197 on 2011-03-09
