I'm trying to install ros-gz on my Ubuntu 22.04.3 laptop with ROS2-Iron & Gazebo-fortress already installed (both using binaries).
First I ran sudo apt-get update
to which I get:
Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:2 http://packages.microsoft.com/repos/code stable InRelease
Hit:3 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:4 http://packages.ros.org/ros2/ubuntu jammy InRelease
Hit:5 http://packages.osrfoundation.org/gazebo/ubuntu-stable jammy InRelease
Hit:6 https://packagecloud.io/sensu/stable/ubuntu jammy InRelease
Hit:7 http://us.archive.ubuntu.com/ubuntu jammy InRelease
Hit:8 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:9 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease
Reading package lists... Done
Then, as suggested in the 'default ros/gazebo pairing' section of this guide, I ran sudo apt-get install ros-iron-ros-gz
& I'm getting the below 404 Not found errors:
Building dependency tree... Done
The following additional packages will be installed:
ros-iron-compressed-depth-image-transport ros-iron-compressed-image-transport ros-iron-image-transport-plugins ros-iron-ros-gz-bridge ros-iron-ros-gz-image
ros-iron-ros-gz-interfaces ros-iron-ros-gz-sim ros-iron-ros-gz-sim-demos ros-iron-theora-image-transport
The following NEW packages will be installed:
ros-iron-compressed-depth-image-transport ros-iron-compressed-image-transport ros-iron-image-transport-plugins ros-iron-ros-gz ros-iron-ros-gz-bridge
ros-iron-ros-gz-image ros-iron-ros-gz-interfaces ros-iron-ros-gz-sim ros-iron-ros-gz-sim-demos ros-iron-theora-image-transport
0 upgraded, 10 newly installed, 0 to remove and 5 not upgraded.
Need to get 2,354 kB/2,670 kB of archives.
After this operation, 24.0 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-compressed-depth-image-transport amd64 3.1.0-1jammy.20231117.112549
404 Not Found [IP: 140.211.166.134 80]
Err:2 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-compressed-image-transport amd64 3.1.0-1jammy.20231117.112554
Err:3 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-theora-image-transport amd64 3.1.0-1jammy.20231117.110033
Err:4 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-image-transport-plugins amd64 3.1.0-1jammy.20231117.114631
Err:5 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-ros-gz-bridge amd64 0.247.0-1jammy.20231117.114732
Err:6 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-ros-gz-image amd64 0.247.0-1jammy.20231117.120950
Err:7 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-ros-gz-sim amd64 0.247.0-1jammy.20231117.103229
Err:8 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-ros-gz-sim-demos amd64 0.247.0-1jammy.20231117.121601
Err:9 http://packages.ros.org/ros2/ubuntu jammy/main amd64 ros-iron-ros-gz amd64 0.247.0-1jammy.20231117.121640
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-compressed-depth-image-transport/ros-iron-compressed-depth-image-transport_3.1.0-1jammy.20231117.112549_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-compressed-image-transport/ros-iron-compressed-image-transport_3.1.0-1jammy.20231117.112554_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-theora-image-transport/ros-iron-theora-image-transport_3.1.0-1jammy.20231117.110033_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-image-transport-plugins/ros-iron-image-transport-plugins_3.1.0-1jammy.20231117.114631_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-ros-gz-bridge/ros-iron-ros-gz-bridge_0.247.0-1jammy.20231117.114732_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-ros-gz-image/ros-iron-ros-gz-image_0.247.0-1jammy.20231117.120950_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-ros-gz-sim/ros-iron-ros-gz-sim_0.247.0-1jammy.20231117.103229_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-ros-gz-sim-demos/ros-iron-ros-gz-sim-demos_0.247.0-1jammy.20231117.121601_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-ros-gz/ros-iron-ros-gz_0.247.0-1jammy.20231117.121640_amd64.deb 404 Not Found [IP: 140.211.166.134 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
So, I tried sudo apt-get install ros-iron-ros-gz --fix-missing
as suggested in the last line of the above output. To which I get:
Selecting previously unselected package ros-iron-ros-gz-interfaces.
(Reading database ... 351139 files and directories currently installed.)
Preparing to unpack .../ros-iron-ros-gz-interfaces_0.247.0-1jammy.20231117.085929_amd64.deb ...
Unpacking ros-iron-ros-gz-interfaces (0.247.0-1jammy.20231117.085929) ...
Setting up ros-iron-ros-gz-interfaces (0.247.0-1jammy.20231117.085929) ...
Processing triggers for libc-bin (2.35-0ubuntu3.5) ...
So I thought of trying to install ros-gz
from source following the instructions here. I ran:
export GZ_VERSION=fortress
mkdir -p ~/ws/src
cd ~/ws/src
git clone https://github.com/gazebosim/ros_gz.git -b iron
cd ~/ws
rosdep install -r --from-paths src -i -y --rosdistro iron
I'm getting similar 404 errors:
executing command [sudo -H apt-get install -y ros-iron-image-transport-plugins]
The following package was automatically installed and is no longer required:
Use 'sudo apt autoremove' to remove it.
ros-iron-compressed-depth-image-transport ros-iron-compressed-image-transport ros-iron-theora-image-transport
ros-iron-compressed-depth-image-transport ros-iron-compressed-image-transport ros-iron-image-transport-plugins ros-iron-theora-image-transport
0 upgraded, 4 newly installed, 0 to remove and 5 not upgraded.
Need to get 660 kB of archives.
After this operation, 3,529 kB of additional disk space will be used.
404 Not Found [IP: 64.50.233.100 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-compressed-depth-image-transport/ros-iron-compressed-depth-image-transport_3.1.0-1jammy.20231117.112549_amd64.deb 404 Not Found [IP: 64.50.233.100 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-compressed-image-transport/ros-iron-compressed-image-transport_3.1.0-1jammy.20231117.112554_amd64.deb 404 Not Found [IP: 64.50.233.100 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-theora-image-transport/ros-iron-theora-image-transport_3.1.0-1jammy.20231117.110033_amd64.deb 404 Not Found [IP: 64.50.233.100 80]
E: Failed to fetch http://packages.ros.org/ros2/ubuntu/pool/main/r/ros-iron-image-transport-plugins/ros-iron-image-transport-plugins_3.1.0-1jammy.20231117.114631_amd64.deb 404 Not Found [IP: 64.50.233.100 80]
ERROR: the following rosdeps failed to install
apt: command [sudo -H apt-get install -y ros-iron-image-transport-plugins] failed
apt: Failed to detect successful installation of [ros-iron-image-transport-plugins]
I ran autoclean
& autoremove
and re-ran the above binary & source installation commands. The outputs are still the same.
Troubleshooting:
Output of head -n 20 /var/lib/apt/lists/packages.ros.org_ros2_ubuntu_dists_jammy_InRelease
is:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA256
Origin: ROS
Label: ROS jammy
Suite: jammy
Codename: jammy
Date: Fri, 29 Dec 2023 06:23:19 UTC
Architectures: i386 amd64 arm64 armhf
Components: main
Description: ROS jammy Debian Repository
MD5Sum:
bae85853deff5b3319df842a8f597a4c 139069 main/binary-i386/Packages
42f2cd693ccc79e03f890c1e60518c2e 39083 main/binary-i386/Packages.gz
ba1f11e611741566ab55f819d4a3c2fd 120 main/binary-i386/Release
ec65091ea65caeaa2059ee0f8e5a00e1 5431287 main/binary-amd64/Packages
a3ba72d0b41c1517422ff2b982455db1 1422935 main/binary-amd64/Packages.gz
6e8bf3a6440d38bb57959b4c19d096c4 121 main/binary-amd64/Release
b552b11e559995233c7431c6007ab5fe 5281964 main/binary-arm64/Packages
7f23b7d4afe02ad57bed496bc7be38a0 1386999 main/binary-arm64/Packages.gz
Then running sudo apt-get update
produces:
Hit:1 http://us.archive.ubuntu.com/ubuntu jammy InRelease
Hit:3 http://packages.ros.org/ros2/ubuntu jammy InRelease
Hit:4 http://us.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:5 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:6 http://us.archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit:7 https://dl.google.com/linux/chrome/deb stable InRelease
Hit:8 http://packages.osrfoundation.org/gazebo/ubuntu-stable jammy InRelease
Hit:9 https://packagecloud.io/sensu/stable/ubuntu jammy InRelease
Followed by quickly running head -n 20 /var/lib/apt/lists/packages.ros.org_ros2_ubuntu_dists_jammy_InRelease
again produces the same exact output (I stored the outputs in text files & did a vimdiff to check) as it did before the apt-get update
Further apt-cache policy ros-iron-image-transport-plugins
produces:
ros-iron-image-transport-plugins:
Installed: (none)
Candidate: 3.1.0-1jammy.20231117.114631
Version table:
3.1.0-1jammy.20231117.114631 500
500 http://packages.ros.org/ros2/ubuntu jammy/main amd64 Packages
Please let me know if you want me to run any more commands and paste the outputs. Any help is greatly appreciated. Thanks!
