Hi everybody,
I've just installed a fresh version of Ubuntu 15.10 "Wily Werewolf" on my VMWare Player. I want to install the latest version of ROS (which is "Jade Turtle" I assume). When going through the installation tutorial I've noticed already on step 1.2 the first problem.
ROS Jade ONLY supports Trusty (14.04), Utopic (14.10) and Vivid (15.04) for debian packages.
As I am running 15.10, I assume, that ROS Jade doesn't support debian packages on my special system. As I am not experienced with Ubuntu, I can only guess that the next steps of the tutorial won't for me as this is a pretty basic requirement for the system.
Does anyone has a easier-to-understand installing guide for me (I know that the tutorial I mentioned above is really simple already)?
Thanks in advance! Che.
Originally posted by Che. on ROS Answers with karma: 48 on 2015-12-17
Sorry, I've already found an answer in this board. http://answers.ros.org/question/220167/error-installing-ros-indigo-on-ubuntu-1510/
Greets.
Originally posted by Che. with karma: 48 on 2015-12-17
Comment by luketheduke on 2015-12-17:
If you've answered your question, please mark your answer as correct so other ROS users can benefit from your question.
Comment by Che. on 2015-12-18:
Hi Luke, this is not possible.
10 points required to accept or unaccept your own answer
Comment by luketheduke on 2015-12-18:
If you want to you can ask one of the moderators and they can probably do it for you.
Now I've got the required points to set my own answer as solution ;)
Good for you!
Indeed!!!!
