Can anyone help me solve this problem?
I try using error msg to search on google but have no solution
Thanks !
My system : windows10/ VMWARE/ ubuntu 18.04 / ROS melodic
My webrtc insall step
cd ~
git clone https://chromium.googlesource.com/chromium/tools/depot_tools.git
sudo vim ~/.bashrc
export PATH="$PATH:~/depot_tools"
source ~/.bashrc
mkdir webrtc-checkout
cd webrtc-checkout
fetch --nohooks webrtc
gclient sync
My webrtc_ros install step:
cd catkin_ws/src
git clone https://github.com/RobotWebTools/webrtc_ros.git
cd ..
catkin_make -DCATKIN_WHITELIST_PACKAGES="webrtc_ros"
**Below is my error log:**
[ 64%] Building CXX object webrtc_ros/webrtc_ros/CMakeFiles/webrtc_ros_server.dir/src/ros_video_capturer.cpp.o
In file included from /home/jetbot/catkin_ws/src/webrtc_ros/webrtc_ros/src/ros_video_capturer.cpp:1:0:
/home/jetbot/catkin_ws/src/webrtc_ros/webrtc_ros/include/webrtc_ros/ros_video_capturer.h:6:10: fatal error: webrtc/media/base/adapted_video_track_source.h: No such file or directory
#include <webrtc/media/base/adapted_video_track_source.h>
compilation terminated.
webrtc_ros/webrtc_ros/CMakeFiles/webrtc_ros_server.dir/build.make:134: recipe for target 'webrtc_ros/webrtc_ros/CMakeFiles/webrtc_ros_server.dir/src/ros_video_capturer.cpp.o' failed
make[2]: *** [webrtc_ros/webrtc_ros/CMakeFiles/webrtc_ros_server.dir/src/ros_video_capturer.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
In file included from /opt/ros/melodic/include/async_web_server_cpp/websocket_connection.hpp:5:0,
from /opt/ros/melodic/include/async_web_server_cpp/websocket_request_handler.hpp:5,
from /home/jetbot/catkin_ws/src/webrtc_ros/webrtc_ros/src/webrtc_web_server.cpp:11:
/opt/ros/melodic/include/async_web_server_cpp/websocket_message.hpp:15:19: warning: missing terminating ' character
# warning I don't know how to create a packed struct with your compiler
CMakeFiles/Makefile2:560: recipe for target 'webrtc_ros/webrtc_ros/CMakeFiles/webrtc_ros_server.dir/all' failed
make[1]: *** [webrtc_ros/webrtc_ros/CMakeFiles/webrtc_ros_server.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
Originally posted by asps946701 on ROS Answers with karma: 3 on 2022-10-03
Comment by ravijoshi on 2022-10-03:
The webrtc_ros
depends on webrtc
. Make sure webrtc
is installed properly.
Comment by asps946701 on 2022-10-03:
I will install webrtc. Thanks you !!
Comment by asps946701 on 2022-10-06:
Do you have webrtc_ros insatll guide after ros was installed.
I was installed webrtc but it got many error. Trying some solution but also fail .Thnaks
Part of error :
-/opt/ros/melodic/include/webrtc/media/base/adapted_video_track_source.h:16:10: fatal error: absl/types/optional.h: No such file or directory
#include "absl/types/optional.h"
-/home/jetbot/catkin_ws/src/webrtc_ros/src/ros_video_renderer.cpp:19:36: error: ‘I420BufferInterface’ is not a member of ‘webrtc’ const rtc::scoped_refptrwebrtc::I420BufferInterface& buffer = frame.video_frame_buffer()->ToI420();
-/home/jetbot/catkin_ws/src/webrtc_ros/src/ros_video_renderer.cpp:21:22: error: base operand of ‘->’ is not a pointer cv::Mat bgra(buffer->height(), buffer->width(), CV_8UC4);
