I did a upgrade to Indigo so I could get Rviz working properly. I am trying to install the xv_laser_driver. I get an error with catkin_make. This is what I get:
Base path: /home/brent/catkin_ws Source space: /home/brent/catkin_ws/src Build space: /home/brent/catkin_ws/build Devel space: /home/brent/catkin_ws/devel Install space: /home/brent/catkin_ws/install
Running command: "make cmake_check_build_system" in "/home/brent/catkin_ws/build"
Running command: "make -j2 -l2" in "/home/brent/catkin_ws/build"
[ 0%] Built target _beginner_tutorials_generate_messages_check_deps_AddTwoInts [ 0%] Built target beginner_tutorials_generate_messages_check_deps_Num [ 0%] Built target std_msgs_generate_messages_lisp [ 0%] Built target std_msgs_generate_messages_cpp [ 0%] Built target std_msgs_generate_messages_py [ 16%] [ 25%] Built target rbx1_nav_gencfg Building CXX object xv_11_laser_driver/CMakeFiles/neato_laser_publisher.dir/src/neato_laser_publisher.cpp.o [ 41%] Built target beginner_tutorials_generate_messages_lisp [ 58%] Built target beginner_tutorials_generate_messages_cpp [ 91%] Built target beginner_tutorials_generate_messages_py [ 91%] Built target beginner_tutorials_generate_messages [100%] Building CXX object xv_11_laser_driver/CMakeFiles/neato_laser_publisher.dir/src/xv11_laser.cpp.o /home/brent/catkin_ws/src/xv_11_laser_driver/src/xv11_laser.cpp: In member function ‘void xv_11_laser_driver::XV11Laser::poll(sensor_msgs::LaserScanstd::allocator<void >::Ptr)’: /home/brent/catkin_ws/src/xv_11_laser_driver/src/xv11_laser.cpp:109:7: error: ‘rpms’ was not declared in this scope rpms=0; ^ make[2]: *** [xv_11_laser_driver/CMakeFiles/neato_laser_publisher.dir/src/xv11_laser.cpp.o] Error 1 make[2]: *** Waiting for unfinished jobs.... /home/brent/catkin_ws/src/xv_11_laser_driver/src/neato_laser_publisher.cpp: In function ‘int main(int, char**)’: /home/brent/catkin_ws/src/xv_11_laser_driver/src/neato_laser_publisher.cpp:71:23: error: ‘class xv_11_laser_driver::XV11Laser’ has no member named ‘rpms’ rpms.data=laser.rpms; ^ make[2]: *** [xv_11_laser_driver/CMakeFiles/neato_laser_publisher.dir/src/neato_laser_publisher.cpp.o] Error 1 make[1]: *** [xv_11_laser_driver/CMakeFiles/neato_laser_publisher.dir/all] Error 2 make: *** [all] Error 2 Invoking "make" failed
I know you guys are probably tired from my on going problem with this tutorial, but I do appreciate your help.
Originally posted by Morpheus on ROS Answers with karma: 111 on 2014-09-01
No need to comment anything, just declare rpms in xv11_laser.h
gedit ~/catkin_ws/src/xv_11_laser_driver/include/xv_11_laser_driver/xv11_laser.h
Add the following to line 43 after public: then save the file
uint16_t rpms;
Run catkin_make in your catkin workspace, and you should be all good now :)
cd ~/catkin_ws/
catkin_make
source devel/setup.bash
Tested with a Jeston TK1 running Ubutnu 14.04 & Indigo
Originally posted by pikey with karma: 16 on 2014-09-08
Comment by Morpheus on 2014-09-15:
Worked perfect.
Thank you!
