Hi everyone,
I use groovy/ROS with catkin and Eclipse IDE. I need to use btQuaternion for this reason I do include for this #include <LinearMath/btQuaternion.h> in my main program .cpp. Of course LinearMath exist in tf2 package. I add in package.xml the following : <build_depend>tf2</build_depend> <run_depend>tf2</run_depend> . Additinaly I go to propertise->C/C++Include Paths and symbols -> Add External Include Path -> /opt/ros/groovy/stacks/geometry_experimental/tf2/include. However the results were not satisfactory and after build project I get following error:
fatal error: LinearMath/btQuaternion.h: No such file or directory compilation terminated. make[2]: *
or all result of built of project are:
10:27:24 **** Build of project move_monsun@move_monsun **** /usr/bin/make -j8 all /usr/bin/cmake -H/home/amory/catkin_ws/src/move_monsun -B/home/amory/catkin_ws/src/move_monsun --check-build-system CMakeFiles/Makefile.cmake 0 /usr/bin/cmake -E cmake_progress_start /home/amory/catkin_ws/src/move_monsun/CMakeFiles /home/amory/catkin_ws/src/move_monsun/CMakeFiles/progress.marks /usr/bin/make -f CMakeFiles/Makefile2 all make[1]: Entering directory /home/amory/catkin_ws/src/move_monsun' /usr/bin/make -f CMakeFiles/move_monsun.dir/build.make CMakeFiles/move_monsun.dir/depend make[2]: Entering directory /home/amory/catkin_ws/src/move_monsun' cd /home/amory/catkin_ws/src/move_monsun && /usr/bin/cmake -E cmake_depends "Unix Makefiles" /home/amory/catkin_ws/src/move_monsun /home/amory/catkin_ws/src/move_monsun /home/amory/catkin_ws/src/move_monsun /home/amory/catkin_ws/src/move_monsun /home/amory/catkin_ws/src/move_monsun/CMakeFiles/move_monsun.dir/DependInfo.cmake --color= make[2]: Leaving directory /home/amory/catkin_ws/src/move_monsun' /usr/bin/make -f CMakeFiles/move_monsun.dir/build.make CMakeFiles/move_monsun.dir/build make[2]: Entering directory /home/amory/catkin_ws/src/move_monsun' /usr/bin/cmake -E cmake_progress_report /home/amory/catkin_ws/src/move_monsun/CMakeFiles 4 [ 50%] Building CXX object CMakeFiles/move_monsun.dir/src/move_monsun.cpp.o /usr/bin/c++ -Dmove_monsun_EXPORTS -DROS_PACKAGE_NAME="move_monsun" -fPIC -I/home/amory/catkin_ws/src/move_monsun/include -I/opt/ros/groovy/include -o CMakeFiles/move_monsun.dir/src/move_monsun.cpp.o -c /home/amory/catkin_ws/src/move_monsun/src/move_monsun.cpp /home/amory/catkin_ws/src/move_monsun/src/move_monsun.cpp:2:37: fatal error: LinearMath/btQuaternion.h: No such file or directory compilation terminated. make[2]: *** [CMakeFiles/move_monsun.dir/src/move_monsun.cpp.o] Error 1 make[2]: Leaving directory /home/amory/catkin_ws/src/move_monsun' make[1]: *** [CMakeFiles/move_monsun.dir/all] Error 2 make[1]: Leaving directory /home/amory/catkin_ws/src/move_monsun' make: *** [all] Error 2
10:27:27 Build Finished (took 2s.764ms)
Have any one Idee or solution?
thanks
Originally posted by underwater on ROS Answers with karma: 21 on 2013-01-30
I'm not super familiar with building in eclipse, but you may be missing a part of your include path. The full path to btQuaternion.h is:
/opt/ros/groovy/stacks/geometry_experimental/tf2/include/tf2/LinearMath/btQuaternion.h
Your eclipse-property setting only goes up to: .../geometry_experimental/tf2/include, but I think it should also include an additional tf2 directory.
You could also try to compile the package directly from the command line with rosbuild to see if that works. If so, then maybe you just need to re-run make eclipse-project and see if that fixes things.
Originally posted by Jeremy Zoss with karma: 4976 on 2013-03-22
